You really need to supply other information - such as :-
What are your dimension limits
Does it need to be any special shape
Does "5-6" mean 5 or does it mean 6
Does it have to be detachable
Does it have to be anchored (secure) when in place
What is the voltage and current rating
Why does it have to be so small
and any one of a whole bunch of other pieces of information to help your helpers help you
jackrae:
not bigger than about 1cm
Not really but round shaped connectors are easier to install on panels
6 preferable (future proof) but 5 is also ok.
Not sure what the you mean here. Obviously I need a panel mounted receptacle and a matching plug that will be installed at the end of a cable.
Not in the sense of screw plug like an aviation connector has.
5v, 200mA max
Because the actual space available in small. It is intended for installation on a din rail mounted box where other indicators/ controls are also present.
Ultra miniature multiway connection might possibly be achieved using the body of a microSD memory card and its mating socket mounted into your DIN rack enclosure.
Mini USB is pretty obsolete these days, yet quite well available at the same time.
It's small, and has 5 poles (so it is not future proof, but so is mini USB as well) and is supposed to be capable of handling 500 mA.
It does have your odd shape so mounting it will be a bit of a problem.
Of course, you need to consider someone might be tempted to plug their very old phone charger or something similar in this connector of yours.
Exactly my thoughts!
Indeed USB (even the full size version) would be the perfect size and very discreet as well, however there is an increased risk of being mistaken for its usual application which is why I crossed out this option.
Watcher:
Mind you, it would be at least as big as what I suggested.
