Small connector recommendation needed
I’m looking for a small, panel mount connector with a minimum of 4 pins with matching cable mount connector. I want to add a couple of connectors to the prototyping boxes I’ve built which will allow easy connection of things like a 16x2 LCD display when needed. I have several 4 pin DIN connectors, but they’re on the large size and overkill for what’s needed. I can use the 2.54mm header type connectors, but I’m wanting something more robust than that. One thought is the RJ11 phone type connector.
Any suggestions would be greatly appreciated! Thanks…
Depends on how many time you will be making the connection, which is limited. Also need special tool to crimp the connector to the special, flat cable.
Didn’t realize they made a 4 pole version. Thanks!
They are quite common on analogue PC/smartphone headsets for ground, left channel, right channel and microphone signals.
I use what they call aviation connectors, they come in many different combinations. Here is a link into china: https://www.aliexpress.us/item/3256806187415199.html
Hi, @trek2120
If you need robustness, look at these M12 industrial series.
They come in many pin numbers, worth doing a parametric search on Digikey or Mouser or E14.
Tom.... :smiley: :+1: :coffee: :australia:
If you use that connector, you should ensure you never plug/unplug with your project powered. Otherwise, carefully review the connection arrangement as each ring is sequentially inserted/removed, and ensure you have protected against
  • applying power or ground directly to a digital output
  • applying reverse power, or unreferenced power, to the wrong pin
  • etc.
Think each connection sequence through, else, for example, you’ll be pondering why that pin XX keeps “dying in the field but not in the lab”.
It’s a real risk. There are things that can be done (e.g. series resistance on each digital output routed through such a connector), but the first step is to identify the problems.
@camsysca
I ordered the 4 pole 3.5mm connectors and I’m well aware of the issues with plugging/unplugging while powered on with this type connector. The need to plug an external I2C device won’t happen very often. The only device I have so far is a 20x4 LCD screen that I need occasionally. The prototyping boxes I’ve built have two different size OLED screens and they cover most projects I do. They also have real time clock and Micro SD modules built inside and connected. I only need to activate them if needed. I always power everything off when connecting/disconnecting devices. Thanks!
USB connectors have at least 4 usable pins, and are frequently available in "panel mount" form (although I don't know if they're smaller than the audio jacks, at that point.) It'd probably be a bad idea, anyway...
The problem with panel mount connectors at hobby level is the difficulty in cutting anything other than round holes.
You didn't mention , as far as I can see, whether or not you need environmental protection, e.g. an IP rating.
If that doesn't matter, then the miniature stereo plugs and sockets as mentioned are widely used for pluggable sensors.
I say miniature to distinguish them from larger counterparts like 1/4" GPO plugs.
3.5-mm is common and there is a 2.5-mm version as well. Not sure if 2.5-mm supports 4-pole.
There are also the DIN range of connectors that support up to 6 or 7 pins. Used a lot in audio applications.
Soldering can be challenge. One way to get round that is to buy the plug with lead already attached.
There's a wide choice of round panel sockets.
At the medical/military end, round connectors can be hideously expensive. Lemo is one type in the mid-range pricewise. Very nice for applications needing a good IP rating.
With all these round, ring connectors, you need to pay attention to the possible misconnections during the plugging in/out action. This isn't a problem with pin types.
@tigger
I have a nice laser engraver/cutter I built a few years ago. The enclosure in the prototype box above was cut out using it. It took 12 minutes to engrave and cut out all of the parts.
There are no environmental requirements in this case. This connection will rarely by used, so it doesn’t need to withstand thousands of plug/unplug cycles. Every once in a while, I need to utilize the 20x4 LCD screen. I designed and 3D printed a simple enclosure for it, and have been using the pin wires to connect it to the breadboard. I just it’d be nice to have a simple plug-in connection.
The stereo plugs work well.
They have ground, the tip can be power and two others to choose.
The DIN plugs and sockets are larger, but have the slight advantage of being pins rather than rings.
Plenty to choose from.
I'm using these https://www.jst-mfg.com/product/pdf/eng/eXH.pdf
They are very small, cheap, reliable. In most cases true: don't (dis)connect them when power is on!
Example from weather station:
