PC COM port → MAX3232 → Arduino Uno: COM works, but Arduino receives nothing
Title:
Post:
Hi everyone,
I am trying to send serial data from an old Windows XP PC (real COM port) to an Arduino Uno through a DB9 MAX3232 RS232-to-TTL module.
My goal is simple: send characters from HyperTerminal on the PC and read them on Arduino.
Hardware
  • Windows XP PC with real COM port
  • HyperTerminal
  • Arduino Uno
  • DB9 MAX3232 RS232 ↔ TTL module
  • I tested 2 different MAX3232 modules
Arduino side
MAX3232 connections:
  • VCC → 5V
  • GND → GND
  • TXD → Arduino D10
  • RXD → Arduino D11
What I confirmed
  • PC COM2 works
  • HyperTerminal loopback test works when I short DB9 pin 2 and pin 3
  • COM1 was wrong, COM2 is the real working port
  • HyperTerminal settings are:
    • 9600
    • 8 data bits
    • no parity
    • 1 stop bit
    • flow control none
What I tested between PC and MAX3232
I tried both DB9 wiring options:
1. Straight
  • 2 → 2
  • 3 → 3
  • 5 → 5
2. Null modem
  • 2 → 3
  • 3 → 2
  • 5 → 5
I also tried a 7 ↔ 8 bridge.
Still, Arduino receives nothing in Serial Monitor.
Important observation
If I connect the PC COM signal directly to Arduino D10, I see random bytes in Serial Monitor.
So D10 is reacting, but of course that is raw RS232 and not valid TTL serial data.
That makes me think:
  • PC COM port is working
  • Arduino input is alive
  • the problem is probably in PC ↔ MAX3232 DB9 wiring or how this module is internally wired
My questions
  1. For a setup like PC COM port → DB9 MAX3232 → Arduino Uno, should the DB9 cable be:
  • straight-through
  • or null modem?
  1. Has anyone used this exact type of DB9 MAX3232 module with a PC COM port and Arduino?
  2. Is SoftwareSerial on pins 10/11 a bad choice here?
  3. What is the best way to isolate whether the problem is:
  • PC ↔ MAX3232
  • or MAX3232 ↔ Arduino?
Any advice would be appreciated.
Thanks.
#include <SoftwareSerial.h>
SoftwareSerial rs232(10, 11); // RX, TX
  rs232.begin(9600);
  Serial.println("Ready");
  if (rs232.available()) {
    int c = rs232.read();
    Serial.print("Received byte: ");
    Serial.println(c);
There are examples for software serial in IDE , worth a look .there is a good pass through example
Check your db9 connections it is very easy to confuse pins .
Rx , Tx and 0v .
  • Without sending anything from the XP, what voltage do you measure on DB09 Pins 10 and 11 ?
  • Show us how the MAX3232 is wired in your circuit.
A simple annotated schematic would be much easier to follow. What protocol is the system looking at, there are several both hardware and software.
RS232 is at a higher voltage than 5v - that direct connect could well have destroyed the chip or its digital inputs .( check those with simple input /output sketch ).
.*IF*your computer has a RS232 port ( rare these days ) ,to which you have connected ( not a monitor connector ) to your RS232 to UART module connector , then it is likely to appear as COM port 1 and not appear /disappear on connection.
The MAX 232 clones are easily destroyed , just by looking at them — check again that loop back , by connecting its output, UART, Tx and Rx together and running serial monitor to check anything you type gets repeated back .
Btw I’m confused by your statement of using Rs232 > max232 > Arduino. And also a db9 “module “ - if you used a module , how did you connect rs232 direct to pin d10 ?
some drawings /pictures might help , something is wrong which we aren’t “getting”
Have run the example software serial from the ide. ???
I would at least have used Byte or char instead of int in your coms routine ( and declared it globally - neatness ).
NOTE !! , of course you are sending over software serial and receiving over the usb connection, so you need two instances of the serial monitor running - one to com port 1 to send , one to the com port your usb connection brings up to see your returned data from the Arduino hardware serial connection .
Turn off Cr and new line on the transmitting serial monitor .
Run this :
Nice example
There are quie a few diferent versions of the module, which exact one do you have?
That could have damaged the D10 pin
Look like this?
Use straight through RS232 cable.
waiting for the schematic. A bit of caution RS232 can range from +25V to -25V.
The duck found: RS-232 voltage levels represent logical states for data transmission, where a logical "1" (mark) is indicated by a voltage between -15V and -3V, and a logical "0" (space) is indicated by a voltage between +3V and +15V. This standard allows for reliable communication between devices over serial connections.
for example using a UNO to communicate over RS232 have a look at Arduino-UNO---TTL-and-RS232-serial
@hammy mentioned in post 6 that "The MAX 232 clones are easily destroyed "
this also applies to the TTL-RS232 modules (see photo in post 7)
over the years I had 5 or 6 of these modules fail probably by incorrect wiring
