PC doesn't recognize Arduino
Hi everyone, I'm having a little problem. I have a new computer and I downloaded the Arduino IDE, but it's not recognizing the Arduino on the COMX ports. I think it's a simple problem, but I'm not sure.
Can someone help me?
Welcome!
Gosh I have an old one running Linux and it works great. You might tell us what you have. What operating system is it? What Arduino are you using.
Arduino’s are designed for experimentation and learning,
To ensure we can provide the most accurate assistance, please include detailed information about your setup. Specify the exact board, shield, wiring configuration, and power sources you are using. An annotated schematic is ideal, as it provides a clear overview of your setup, but be sure to also include links to the technical specifications of your hardware components.
Before posting your code, please review the forum guidelines and use code tags for better readability. Also, provide links to the technical information about your hardware, and include a preliminary schematic that shows all power, ground, and connections. For additional guidance, you can refer to this link: Useful Links and Tutorials. Note that in this context, breadboard diagrams are not considered proper schematics.
Hang on while I get my telescope so I can read the messages on your screen.
If you're talking about COMx ports, I assume you're talking about Windows, but you always have to specify everything: OS, IDE version, and which Arduino board you have (with link), together with any other useful information (e.g. what happens when you plug the USB cable in? What do you see in device manager when you plug it in?
This problem is usually caused by the lack of USB-to-serial device drivers for compatible (non-original) Arduino boards, which require the installation of specific drivers depending on the chip used by your board. So, please provide all the information and we can probably help.
