the voltage drop across 10 meter seems to be marginal
Wires also have inductance, especially long ones.
is there a way to calculate it? or I just should do trial with long wire and see if or how it affect the motors?
Yes but how will that help you?
Here is a calculator that gives a theoretical value
https://www.allaboutcircuits.com/tools/wire-self-inductance-calculator/
It's part of the allaboutcircuits online text book that I suggested you read.
Good idea.
As far as capacitors, you should also have a .1uF cap across the PWM chip Vcc-GND
ok, I found this 4 channel mosfet driver board: link (the green one)
it can operate with 3.7V output which is close enough to my 3.3V motors (?) so it might be a good solution?
FFS it's only 70mA and a PCA9685 can only do about 1kHz PWM.
I suggested an ULN for simplicity. You don't need any other parts than the ULN itself.
And you can use a 5volt supply.
Just use one ULN fer 8 motors. Join ULN inputs as required.
Build it, test it, get on with life.
Leo..
Your guess would be as good as mine. I have doubts about many of the claimed specifications.
It does not seem like you want to try to learn anything.
I just ordered the PCA9858 and I will try the circuits offered and see what is works.
In worst case scenario I will get Arduino Mega and Will control each of the motors from individual PWM pin (15 in total).
Yesterday I build the circuit with FQP30N06L that I had at home and it did not work at all (I guess due to fake part that was bought from Aliexpress).
I then check using 2N2222A transistor with 330R base resistor and it was working great. I might use that instead of the MOSFET.
The idea to use the MOSFET was that I could potentially drive different motors that require higher current. But I might just use 2N2222A to drive only those small motors.
Nothing wrong with that.
Buy extra parts and modules in case you burn out or damage something
Some updates. board arrived. works great. Iām using MOSFET for driving the motors. for the moment tried with 4 motors. All works.
Thanks for all the helps
schematics:
Did you buy new MOSFETS because you said they did not work before.
See post #4
A few small things.
- As mentioned, the PCA might have 220R series output resistors. If so R1 is not needed.
- Your D2 Symbol is wrong.
I prefer connecting OE to GND even though there are 10k pull-downs.
High current output power supplies should have fusing.
How is the NANO powered ?
Avoid making a voltage divider, use this circuit.
Correct.
R2 is also not needed.
The gate is connected to a permanent output pin, not to an MCU pin that is an input during bootup.
Leo..
- But my motors run by themselves when I unplug them from the PCA9685
Got you.
But hot-plugging a gate, with or without resistor, is not a wise thing to do.
The base of a 2N2222 transistor is more forgiving there.
Leo..
I did point that out back in post #4
Yes I did, those ones works
Thanks I will do that.
For the testing I'm using Uno, it powered from the USB via the computer (that also control the motors via the Serial) . In the finished version I will use Nano that will be powered from the computer as well (via USB)
regarding the pulldown base resistor - is it needed? @Wawa thinks is not needed. Just reminder Iām using MOSFET and not the bjt
edit: updated schematics:
