I have some questions / doubts on the PCA9685 that I want to use to drive groups of LEDs 0603 (2.9V 20mA) in parallel of variable number on each output (an output with 2, another with 13 LEDs in parallel, etc ..) , I thought about this card because I'm about thirty different releases on which I want to make independent fades, if there are other solutions you can propose as well:
If I have not misunderstood every single output leads to max 25mA, right? So I can directly connect (with due resistance) only 1 or 2 leds at most?
All the outputs have a resistance in series of 220ohm, but in theory for a LED would be enough for 100ohm, how can I do? I remove the resistance from the circuit?
I imagine therefore that if I want to pilot the 13 LEDs in parallel must use a logical mosfet, is the IRL540N OK? Are there any other solutions besides using mosfets? Is it correct to say that 20mA x 13 leds = 260mA will pass?
Since I am using the LED wire (0.1mm copper) for connections with 13 LEDs it overheats? too much current?
