It's a workable solution for devices that can have their weight entirely supported by a tab of PCB material. Also add on stresses from incidental movement and it may not be such a great solution.
If you notice how the USB pins have the outer contacts (power) set further forward, it's like that to prevent the data lines from contacting first and trying to conduct power over data lines. Subtle design point that may get overlooked if going with straight PCB traces and other vectors of connection other than head-on as it was designed in the plugging-in motion.
New connectors typically are low profile surface mount components now, as the excitement is with small high density connectors. These sort of connectors (available in enough styles to make your head spin) can be had from . digikey, mouser or any other professional electronics supplier.
Tricky to use due to needing a package library for your pcb design tool (theyre all different, the small ones at least), and hard to navigate the product t life cycle ( are they gonna stop making them next week, or is it a thriving product line? How do you know?)
Card edge connectors, where pads on the board engage a connector are common, and can be had from any electronics supplier. These are old technology, though, and have been around since the 70s or earlier.
