PCF8575 Arduino/ESP32
hello experts,
shortage of pins
going to use PCF8575
using PCF8575_library
trying from last 2 days for just simple code
getting fustraited
can not understand, whats happened
my code
#include "Arduino.h"
#include "PCF8575.h"
PCF8575 pcf8575(0x20);
  Serial.println("PCF8575");
  pcf8575.begin();
  pcf8575.pinMode(P6, OUTPUT);
  Serial.println("HIGH");
  pcf8575.digitalWrite(P6, HIGH);
  Serial.println("LOW");
  pcf8575.digitalWrite(P6, LOW);
please help
TIA
Help us help.
Post the simple code that doesn't work.
Draw and post, or find and copy here, the schematic showing how you have hooked up the PCF8575.
Are you using a library? Did that come with examples?
You may also get some mileage out of this
beta version, simulated PCF8575
which uses the wokwi simulator.
a7
not understand what u says
its for 8574, which i used back
i am trying for 8575, not getting success
i posted what i wrote
library given in link
@sachenwadekar
The PCF8575 can only sink large currents.
So you need to connect your LED Cathode to the PCF8575 pin, connect the LED Anode to a 330 ohm resistor and connect the other end of the resistor o 5V
Then it will work
Run the I2C scanner to determine if everything is operating correctly. If you do not get a 0X20 as a valid port it will never work. Change that to the port number returned by the scanner. I have some boards that look like the one you have, they do NOT have pull up resistors. They need to be there, something n the 4.7K range should work fine.
tried, not getting OK.
where is the GND ?
GND is the brown wire that you show in the picture in post #1
Vin is connected to 5V
you are correct.
Serial monitor : No I2C devices found
tried many times, on ESP32 and Arduino Nano also
checked I2C address as below
RTC module
I2C device found at address 0x50 !
I2C device found at address 0x68 !
PCF8574
I2C device found at address 0x20 !
PCF8575
may be faulty item or anything else ?
that brown wire is for module, i think so
what is GND for LED ? not needed ?
i am sorry, but will you please make complete sketch
TIA
its done....
the board which i brought, was un-soldered
i soldered it
reviewed again
some pins was partially soldered
repaired it
and
IT's DONE
Thanks to ALL....
thanx jim-p....
will u please tell me the same connection for btns ?
