PCF8575 input pull-up
I am using Arduino Pro micro and PCF8575 I2C expander module (similar like this). However I am wondering why PCF8575 input pull-up doesn't work. If I don't connect any IO-pins of PCF8575 module, shouldn't below code print 1111111111111111 because of input pull-up? However it prints 0000000000000000. The library I use is this.
#include <PCF8575.h>  //https://github.com/xreef/PCF8575_library
//#include <Wire.h>
PCF8575 pcf8575(0x20);
  for(int i=0;i<16;i++) {
    pcf8575.digitalWrite(i, HIGH);
  // Set pinMode to INPUT
    pcf8575.pinMode(i, INPUT);
  pcf8575.begin();
  PCF8575::DigitalInput di = pcf8575.digitalReadAll();
  Serial.print(di.p15);
  Serial.print(di.p14);
  Serial.print(di.p13);
  Serial.print(di.p12);
  Serial.print(di.p11);
  Serial.print(di.p10);
  Serial.print(di.p9);
  Serial.print(di.p8);
  Serial.print(di.p7);
  Serial.print(di.p6);
  Serial.print(di.p5);
  Serial.print(di.p4);
  Serial.print(di.p3);
  Serial.print(di.p2);
  Serial.print(di.p1);
  Serial.println(di.p0);
  delay(2000);
Hi @heke87
Did you run I2Cscanner to make sure the 0x20 address is correct?
No, but if I connect some IO pin to 3V3 then the pin is printed 1. So PCF8575 communicates correctly with Arduino.
Posting a schematic would help. Also what value of pull ups are you using on the I2C bus. Run the scanner just to make us happy:-) It should read the same every time.
Pull up resistors on the PCF8575 pcb are 10kohm (between VCC - SCL and VCC - SDA). I2CScanner prints "I2C device found at address 0x20" everytime. Schematic is this:
Hi
I don't have the micro arduino nor the PCF8575, but I have an arduino mini and a PCF8574 which is similar to PCF8574.
I'm going to mount here on the breadboard and see what goes with your code.
Hi
I used the PCF8575.h library with PCF8574 and got these results with the changes I made to its code.
Note: The I2C address of my PCF is 0x38
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
//#include <Wire.h>
PCF8575 pcf8575(0x38);     // My PCF8574 address
  pcf8575.pinMode(P0, INPUT);
  pcf8575.pinMode(P1, INPUT);
  pcf8575.pinMode(P2, INPUT);
  pcf8575.pinMode(P3, INPUT);
  pcf8575.pinMode(P4, INPUT);
  pcf8575.pinMode(P5, INPUT);
  pcf8575.pinMode(P6, INPUT);
  pcf8575.pinMode(P7, INPUT);
  pcf8575.begin();
  delay(2000);
I am going to take a SWAG because I do not use a library for that part. That is what it should be reading. When it is initialized the output pins are written as one's. This is because it is a quasi I/O port with week pull up fets and a N-fet as the output driver. Try writing alternating 0x55 and 0xAA between the reads, the bits will switch each time you write the alternate value.
I tried this code (below) which should change pins states between reads but no change. It always writes 0000000000000000. Maybe PCF8575 is broken?
I don't know how to write 0x55 or 0xAA with this library. Could you show code that should worked with only wire.h library? I could test it.
  pcf8575.begin();
      pcf8575.digitalWrite(i, LOW);
  delay(2000);
Do you have a DMM? What does it say? Try to use a LED (with a current limiting resistor) to see if the pins are driven LOW or HIGH or floating.
I measured pins states with DMM and it shows that they are at LOW state (= 0V). I used the code from my first message. I also tried to loop this code to see if pcf8757.digital.ReadAll() mixes something but it didn't change anything and DMM measured still 0V in all 16 IO-pins.
IIRC all pins are set to HIGH/INPUT at power up. Try to disconnect it from Arduino, power up and try to measure pins again.
I disconnect PCF8575 from Arduino, only GND and VCC is used. All pins seems to floating when it is measured with DMM.
