If there is anyone interested in getting the Arduino talking directly to Pd on a Mac (OSX Tiger) then the following may prove usefull. Sorry for my simplistic description of the proceedure.
The first stage is obvious - install all the software from the Arduino site ie 'Arduino 0003' and the USB serial driver. Now download the 'Pd-0.38.4-extended-RC7' from Hans-Christoph Steiner's website.
http://puredata.org/Members/hans/downloads/installers/Pd-0.38.4-extended-RC7.dmg
Follow his really simple install instructions. This version of Pd is packaged as an app, so it is ultra easy to install. Don't forget to put the 'org.puredata.pd.plist' file in your '~/Library/Preferences' directory as it will load all the externs when Pd opens.
The next thing to do is find out the path of your Arduino. To do this you need to plug the Arduino in to the USB port. Open the 'Arduino 0003' application and goto the 'Tools/Serial Port' menu and look for a device path that includes 'tty.' but NOT 'modem'. My path is: '/dev/tty.usbserial-0B2'. Write this path down as you'll need it in Pd. In order to test communication I ammended (simplified) the 'serial_write_basic' file. It says 'hello' every 5 seconds. Here is the code.
/* Serial Ping
say hello every 5 seconds
int val = 0; // variable to store the data from the serial port
beginSerial(9600); // connect to the serial port
void loop () {
printString("hello");
printNewline();
delay(5000); // convenient to use delays when sending stuff back to the comp.
// end
Also take a note of the baud rate (9600) as we need that info in Pd too. Upload this code onto your Arduino. You can quit the Arduino app and leave the board plugged in and running it's futile attempts to make friends.
The real business is setting up Pd to receive the hello message. We do this with the 'comport' object, written by Winfried Ritsch. If you know Pd then insert an object and enter 'comport 1 9600' into it's body. The '1' is the port number and the '9600' the baud rate. The comport object needs a message to set the path to the Arduino. Make a message with 'devicename /dev/tty.usbserial-0B2' and connect this to the comport object inlet (upper left). You will probably see an error message in the Pd window. Ignor it. Save your patch, click the message to send it to the comport object and then close the patch. Reopen the patch and it should start receiving the data from the Arduino. The message comes in as character bytes, so 'hello' is received as - 104,101,108,108,110,10 (return).
I know this is the 'hello world' tutorial but Pd is open source, like Arduino, and fun to be with.
Now to do something interesting. I'll make a .zip of the info and post it somewhere if anyone needs it.
