I can't read data from the PDM microphone of the Arduino Nano RP2040 Connect. I used the example provided in this link: https://docs.arduino.cc/tutorials/nano-rp2040-connect/rp2040-microphone-basics. However, the output sample value remained at -128 and did not change. I am wondering how to confirm whether the hardware of the microphone is faulty or if there are some software issues?
Start from showing yohr test code
#include <WiFiNINA.h>
#include <PDM.h>
bool LED_SWITCH = false;
// default number of output channels
static const char channels = 1;
// default PCM output frequency
static const int frequency = 16000;
// Buffer to read samples into, each sample is 16-bits
short sampleBuffer[512];
// Number of audio samples read
volatile int samplesRead;
pinMode(LEDB, OUTPUT);
while (!Serial);
// Configure the data receive callback
PDM.onReceive(onPDMdata);
// Optionally set the gain
// Defaults to 20 on the BLE Sense and -10 on the Portenta Vision Shields
// PDM.setGain(30);
// Initialize PDM with:
// - one channel (mono mode)
// - a 16 kHz sample rate for the Arduino Nano 33 BLE Sense
// - a 32 kHz or 64 kHz sample rate for the Arduino Portenta Vision Shields
if (!PDM.begin(channels, frequency)) {
Serial.println("Failed to start PDM!");
while (1);
// Wait for samples to be read
if (samplesRead) {
// Print samples to the serial monitor or plotter
for (int i = 0; i < samplesRead; i++) {
if (channels == 2) {
Serial.print("L:");
Serial.print(sampleBuffer[i]);
Serial.print(" R:");
i++;
Serial.println(sampleBuffer[i]);
if (sampleBuffer[i] > 10000 || sampleBuffer[i] <= -10000) {
LED_SWITCH = !LED_SWITCH;
if (LED_SWITCH) {
digitalWrite(LEDB, HIGH);
Serial.println("ON!");
else {
digitalWrite(LEDB, LOW);
Serial.println("OFF!");
// Clear the read count
samplesRead = 0;
Callback function to process the data from the PDM microphone.
NOTE: This callback is executed as part of an ISR.
Therefore using `Serial` to print messages inside this function isn't supported.
void onPDMdata() {
// Query the number of available bytes
int bytesAvailable = PDM.available();
// Read into the sample buffer
PDM.read(sampleBuffer, bytesAvailable);
// 16-bit, 2 bytes per sample
samplesRead = bytesAvailable / 2;
I Have the same problem, have you found any solution???
Replying so this doesn't auto-close. I have the exact same problem running the exact same code. Has anyone found a solution?
Install the latest Package Core for the board and also install the library indicated in the screenshot below. Then run the example (https://docs.arduino.cc/tutorials/nano-rp2040-connect/rp2040-microphone-basics) again.
Thanks for the suggestion. Unfortunately I'm still seeing the same problem.
To be extra safe I tried uninstalling all libraries and core packages that I have in the Arduino IDE 2.2.1. Then I installed the following three packages:
- Arduino Mbed OS Nano Boards - version 4.0.8 (through the Boards Manager)
- Adafruit Zero PDM Library - version 1.2.1 (through the Library Manager)
- WifiNINA - version 1.8.14 (through the Library Manager)
When I then uploaded the sketch provided in the Reading Microphone Data on Nano RP2040 Connect I got the same behavior described in the original post. Every value in the Serial Monitor is "-128".
It is highly likely that the onboard microphone is faulty. If still under warranty, contact the retailer/distributor or if bought from Arduino directly contact Arduino via Contact Us
Popping back in here to confirm that @dozieagada24 was right. It seems like the hardware was faulty.
I purchased the original faulty Nano RP2040 Connect (with headers) from Amazon. After running into the problem described in this thread, I purchased another Nano RP2040 Connect (without headers) directly from Arduino. I just received it and tested it out and it appears to be working correctly.
This is happening to me also. Bought Rp2040 from Arduino official store a couple years ago but never used. Today it only reads -128. Considering that few people report the issue, I'm not sure it is an hardware problem (unless a whole batch of boards were faulty). I updated the core to 4.0.10 but still not working.
Found this here in the forum: Ardunio nano rp2040 microphone not available - #4 by sterretje
It suggests sampling frequency should be 20 kHz, not 16 kHz.
Cannot test now, but will soon.
Nice find @eloquentarduino!. Thanks for sharing that link. I can confirm it solved the problem for me.
There's a note in the Nano RP2040 Connect Cheat Sheet that describes this exact situation and the recommended solution:
- Please note: The sampling frequency in the PDMSerialPlotter example is set to 16000 Hz. If the microphone appears to not be working (monitor is printing a value of -128), try to change this rate to 20000 Hz. You can change this at the top of the PDMSerialPlotter example sketch, as shown in the example below:
static const int frequency = 20000; //frequency at 20 KHz instead of 16 KHz
that's works for mee thank you
