For a project I need to get audio data from microphones of an Arduino Nicla Voice and an Arduino Nano RP2040 connect.
By using the provided example from the "NDP examples/Record_and_stream" of the Nicla Voice, and by using a python script to retrieve serial data, I managed to get the audio of the Nicla Voice's microphone and can listen to it with audacity in a g722 format (thanks to the AudioTools library encoders).
For the RP2040 microphone, the exemple is the "PDMSerialPlotter" example and stream PDM data through the serial port. The data seem to be raw data and are of the short type (so signed 16 bits ?).
I tried using a python script (with the scipy library) to retrieve and convert the 16bits data to a wav format but get non listenable results (the convertion "works" but it doesn't correspond to sounds played while recording)
I also tried using the G722 encoder from the AudioTools library with the RP2040 PDM data but I get multiple errors while using this code :
This example reads audio data from the on-board PDM microphones, and prints
out the samples to the Serial console. The Serial Plotter built into the
Arduino IDE can be used to plot the audio data (Tools -> Serial Plotter)
Circuit:
- Arduino Nano 33 BLE board, or
- Arduino Nano RP2040 Connect, or
- Arduino Portenta H7 board plus Portenta Vision Shield, or
- Arduino Nicla Vision
This example code is in the public domain.
#include <PDM.h>
#include "AudioTools.h"
#include "AudioCodecs/CodecG722.h"
//#include "AudioI2S/I2SRP2040.h"
G722Encoder encoder;
// default number of output channels
static const char channels = 1;
// default PCM output frequency
static const int frequency = 16000;
// Buffer to read samples into, each sample is 16-bits
short sampleBuffer[512];
// Number of audio samples read
volatile int samplesRead;
while (!Serial);
AudioBaseInfo bi;
bi.sample_rate = 16000;
bi.channels = 0;
encoder.setOptions(0);
encoder.begin();
// Set the output stream for the encoder to the serial port
encoder.setOutput(Serial);
// Configure the data receive callback
PDM.onReceive(onPDMdata);
// Optionally set the gain
// Defaults to 20 on the BLE Sense and 24 on the Portenta Vision Shield
// PDM.setGain(30);
// Initialize PDM with:
// - one channel (mono mode)
// - a 16 kHz sample rate for the Arduino Nano 33 BLE Sense
// - a 32 kHz or 64 kHz sample rate for the Arduino Portenta Vision Shield
if (!PDM.begin(channels, frequency)) {
Serial.println("Failed to start PDM!");
while (1);
// Wait for samples to be read
if (samplesRead) {
// Print samples to the serial monitor or plotter
/*for (int i = 0; i < samplesRead; i++) {
Serial.println(sampleBuffer[i]);
encoder.write(sampleBuffer, samplesRead);
// Clear the read count
samplesRead = 0;
* Callback function to process the data from the PDM microphone.
* NOTE: This callback is executed as part of an ISR.
* Therefore using `Serial` to print messages inside this function isn't supported.
void onPDMdata() {
// Query the number of available bytes
int bytesAvailable = PDM.available();
// Read into the sample buffer
PDM.read(sampleBuffer, bytesAvailable);
// 16-bit, 2 bytes per sample
samplesRead = bytesAvailable / 2;
ATTENTION: la bibliothèque I2S prétend être exécutable sur la (ou les) architecture(s) rp2040 et peut être incompatible avec votre carte actuelle qui s'exécute sur mbed_nano.
ATTENTION: la bibliothèque AudioBufferManager prétend être exécutable sur la (ou les) architecture(s) rp2040 et peut être incompatible avec votre carte actuelle qui s'exécute sur mbed_nano.
In file included from C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioI2S/I2SRP2040.h:8:0,
from C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioI2S/I2SStream.h:16,
from C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioTools.h:60,
from C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino:16:
C:\Users\User\Documents\Arduino\libraries\I2S\src/I2S.h:137:5: error: 'PIOProgram' does not name a type
PIOProgram _i2s;
C:\Users\User\Documents\Arduino\libraries\I2S\src/I2S.h:138:5: error: 'PIO' does not name a type; did you mean 'EIO'?
PIO _pio;
EIO
In file included from C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioPWM/AudioPWM.h:6:0,
from C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioTools.h:61,
C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioPWM/PWMAudioRP2040.h: In member function 'void audio_tools::PWMDriverRP2040::setupPWMPin(pwm_config&, audio_tools::PicoChannelOut&)':
C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioPWM/PWMAudioRP2040.h:131:37: error: invalid conversion from 'pwm_config' to 'uint {aka unsigned int}' [-fpermissive]
pwm_init(pinInfo.slice, &cfg, true);
C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioPWM/PWMAudioRP2040.h:131:47: error: cannot convert 'bool' to 'pwm_config*' for argument '3' to 'void pwm_init(uint, uint, pwm_config*, bool)'
In file included from C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioPWM/AudioPWM.h:7:0,
C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioPWM/PWMAudioMBED.h: At global scope:
C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioPWM/PWMAudioMBED.h:17:32: error: conflicting declaration 'using PWMDriver = class audio_tools::PWMDriverMBED'
using PWMDriver = PWMDriverMBED;
C:\Users\User\Documents\Arduino\libraries\audio-tools\src/AudioPWM/PWMAudioRP2040.h:21:34: note: previous declaration as 'using PWMDriver = class audio_tools::PWMDriverRP2040'
using PWMDriver = PWMDriverRP2040;
C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino:34:12: error: 'void audio_tools::setup()' conflicts with a previous declaration
In file included from C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\4.0.2\variants\NANO_RP2040_CONNECT/pinmode_arduino.h:30:0,
from C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\4.0.2\cores\arduino/Arduino.h:26,
from C:\Users\User\AppData\Local\Temp\arduino\sketches\8BD11F1F7567A81BAC09DF15E8AE4FBC\sketch\PDMspG722Encoder.ino.cpp:1:
C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\4.0.2\cores\arduino/api/Common.h:117:6: note: previous declaration 'void setup()'
void setup(void);
C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino:68:11: error: 'void audio_tools::loop()' conflicts with a previous declaration
C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\4.0.2\cores\arduino/api/Common.h:118:6: note: previous declaration 'void loop()'
void loop(void);
C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino: In function 'void audio_tools::setup()':
void setup(void);
C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino:52:7: error: request for member 'onReceive' in 'PDM', which is of non-class type 'audio_tools::I2SSignalType'
C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino:62:12: error: request for member 'begin' in 'PDM', which is of non-class type 'audio_tools::I2SSignalType'
C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino: In function 'void audio_tools::loop()':
void loop(void);
C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino: In function 'void audio_tools::onPDMdata()':
C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino:90:16: error: 'void audio_tools::onPDMdata()' conflicts with a previous declaration
void onPDMdata() {
C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino:90:6: note: previous declaration 'void audio_tools::onPDMdata()'
void onPDMdata() {
C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino:92:28: error: request for member 'available' in 'PDM', which is of non-class type 'audio_tools::I2SSignalType'
C:\Users\User\Documents\Arduino\PDMSerialPlotter\PDMspG722Encoder\PDMspG722Encoder.ino:95:7: error: request for member 'read' in 'PDM', which is of non-class type 'audio_tools::I2SSignalType'
^~~~exit status 1
Compilation error: 'void audio_tools::setup()' conflicts with a previous declaration
In the first error, I looked where the PIOProgram class should be located in the GitHub repository of the Arduino-pico repository and it comes from one of the cores files (this one).
How should I used these core files?
Is there a better/simpler way to retrieve and listen to audio data from the Nano RP2040 Connect board ?
Ideally, I would like to only use raw data from both microphones (uint8_t data from the NiclaVoice and short data from the Nano RP2040) and use externals tools (like a python script) to encode the data in a listenable audio format. But my tries don't seem to work.
If you can help me with 1) retrieving encoded data from the RP2040 microphone or 2) encode and listen to raw data from the Nicla Voice and RP2040 microphone I would be very grateful.
Thanks in advance.
