Photoelectric sensor, arduino and external power supply
Hi guys,
recently I am working on a research project.
In my research, I need to build a machine that can record whether a person steps into the correct square. The prototype will look something like this.
The sensor in the picture is F.T.C-1MR and the wiring diagram looks like this:
So what I am trying to build is whenever some step into the wrong block,
the sensor will detect their foot, switch to NO and sending input to arduino.
I start with one sensor and connect the wires,
the brown wire connect to positive of power supply, and the blue and yellow wire connect to negative. I open the power supply and set the volt to 12.
The voltage difference between the brown wire and the black wire is 12 volts, measured with a multimeter. Seems to work just fine.
However, I’m having issues connect it to arduino.
Reduce DC voltage with resistor
The input voltage for Arduino should preferably not exceed 5 volts.
So I connect black wire--10 ohm --small piece of red wire -- 14 ohm -- GND of the power supply.
Measure the voltage between brown and small piece of red wire, still 12V.
The goal is to reduce the input to 5V so that I can work on the code on arduino.
How do I resolve this problem? Should I connect the GND between arduino and power supply? Or am I just do it wrong?
I'll be very grateful if anyone helps. : )
Post the datasheet for your photoelectric sensor.
If the output will work with 5VDC then just connect the COM (yellow) to Arduino GND.
Connect a 4.7K resistor between the NO and 5V and also connect the NO to an Arduino pin.
Make sure that the 5V power supply ground is also connected to the Arduino GND
Thank you very much for the reply, will try it soon and share the result.
PH&PR_Sensor_datasheet.pdf (1.4 MB)
The exact datasheet on page 14, it's mainly in english.
Will you kind enough to tell me why 4.7kOhm?
Low enough to help reduce noise pick-up but high enough so as not to draw too much current. It's a compromise. You may find you actually need a lower value.
Data sheet not much help.
Before you connect the NO pin to an arduino check it with a voltmeter to see if it goes between 0 and 5V whhen triggered.
Trying to figure it out, so I make this picture to make it easier.
Is this what you meant?
No.
Give me a few minutes to draw a diagram
Any other questions?
Thank you for the help, try it today and it works!
I'm trying to understand it today, this is what I came up with so far:
1.Connecting yellow to GND of arduino is to let arduino had a refernce point to determine the signal voltage.
2.When the sensor detects an object, the yellow wire and black wire close to form a circuit, allowing 5V to flow into the input and eventually into the GND.
Am I right?
Actually the other way around.
When it is NOT triggered the yel and blk are disconnected so the 4.7K resistor applies 5V to the input pin and it will read HIGH
When triggered, the yel and blk are connected and the input pin is now connected to GND, so the input will read LOW.
It is a common circuit for detecting switch closures. The 4.7K resistor is called a pull-up resistor.
I get it now!
I look it up, is pull-up resistors using parallel connection with resistor inside the arduino so that output can have higher voltage?
You don't need the internal INPUT_PULLUP when using an external pull-up but it won't do any harm.
Thank you jim!
My problem is solved for now!
You sure are really experienced in electrical engineering.
I will continue working on this project.
No obligation to do so but let us know how it works out.
Have a nice day!
I'm glad you got it working. I'm wondering if perhaps you might have been able to keep it 12v??
The ADC can be configured to have different voltages.
I think this sets it to 5v, but there is a different setting to have it get an external reference voltage which could be 5v
ADMUX |= (1 << REFS0); // set reference voltage
Just a thought
Thanks for the knowledge!
Will try it if I need this feature in the future!
You are not using the ADC, so @c-compute comment is not relavent and as you already know you should never apply 12V to any ardiono pin
Late update:
The project is going pretty well and the machine is almost done!
This machine is inspire by Zhang(2023)[1],
The way sensors connected to arduino and external power source is by the solution of jim-p, and I just parallel connect them. I also use a relay to light up the 12V LED.
The rule of the machine is it will semi-ramdom select a set to light up the LED, the subject needs to step in the cube. Here is the code :
Arduino_project.txt (6.6 KB)
Hope it helps! For anyone might need it!
[1] Zhang, Z., Xiang, T., Guo, H., Ma, L., Guan, Z., & Fang, Y. (2023). Impact of physical and mental fatigue on construction workers’ unsafe behavior based on physiological measurement. Journal of safety research , 85 , 457-468.
I'm impressed!
