Photoresistor
Hello,
Big newbie here. Basically I'm trying to take the example listed on: Arduino Playground - PhotoResistor and do the opposite behavior with it. Meaning when the resistor value is lower, the LED is also lower. Bright light in = bright LED. Been playing around with it for a while and can't seem to get it to work. Any suggestions?
Thanks
This might do the trick.
Since currently it goes from 0 - 255, if you subtract that from 255, it will make it go 255 - 0.
analogWrite(ledPin, 255 - analogRead(lightPin)/4);
Thanks! Makes sense. Also the function:
Serial.println(255-analogRead(lightPin)/4);
seems to work as well.
Problem now is when the value gets lower, the LED starts blinking/flashing like crazy.
Final code with help from a friend:
int prmin = 600;
int prmax = 1000;
int lightPin = A0;
int ledPin=11;
pinMode( lightPin, INPUT);
pinMode( ledPin, OUTPUT );
// input voltage on A0 of 2.5v to 3.3v, clamp and map to an appropriate range
// step 1: read A0
int val = analogRead(lightPin);
// step 2: constrain it to our expected range (based on MATH)
val = constrain(val, prmin, prmax);
// step 3: map the range [511, 675] to the range [0, 255]
val = map(val, prmin, prmax, 0, 255);
// step 4: write the result out to the pwm pin
analogWrite(ledPin, val);
// step 5: diagnostic println()
Serial.println(val);
