Pico mbed-core wire.h: how to specify SDA / SCL-pins?
Hi everybody I was looking up the wire.h and the wire.cpp-file of the
Raspberry pico mbed-core
trying to understand how SDA / SCL-pins can be chosen.
There is this part of the code
class MbedI2C : public HardwareI2C
  public:
    MbedI2C(int sda, int scl);
which seems to deal with specifying the SDA / SCL-pins.
But I have no idea what I would have to write in my code because
using wire is done without any explicit constructor
there is only
wire.begin();
and that's it.
void arduino::MbedI2C::begin() {
	end();
	master = new mbed::I2C(_sda, _scl);
the begin-function uses _sca, _scl but the heck from where do the values come from?
where are the values for the SDA-pin / SCL-pin set???
Whenever I see a demo-code using I2C there is only
wire.begin();
with empty parenthesis
The Earl Philhower-core has explicit functions for this which I understand.
But I do not understand how to assign particular I2C pins in the mbed-core.
There is a public function in the library that takes the pin number as follows
  public:
    MbedI2C(PinName sda, PinName scl);
    virtual void begin();
Maybe try using that ?
Sure. What you have posted is the declaration.
But how does the code look like that makes use of this declaration?
How does the code look like that I write into my *.ino-file?
This declaration has again just a
without any parameters.
There is this mysterious
which has a completely different name.
In my *.ino-sketch: do I write
MbedI2C(6,7);
There is no harm in trying it
I have installed the earl Philhower-core
I explicitly don't want to install the mbed-core
So I can't test it. You seem to not want to answer my question directly.
I guess I have to wait until somebody else gives a direct answer.
That is because I don't know the answer !
Well, if I'm not mistaken I think it's here (from "Wire.cpp"):
#if WIRE_HOWMANY > 0
arduino::MbedI2C Wire(I2C_SDA, I2C_SCL);
#endif
#if WIRE_HOWMANY > 1
arduino::MbedI2C Wire1(I2C_SDA1, I2C_SCL1);
#endif
#if WIRE_HOWMANY > 2
arduino::MbedI2C Wire2(I2C_SDA2, I2C_SCL2);
#endif
However custom SDA/SCL can be used using MbedI2C 2-parameters constructor overload.
Hi @docdoc
thank you for contributing to my thread.
Still your post does not explicitly show
how does the code in the
*.ino-file
look like that will specify certain IO-pins as SDA / SCL?
I'm sorry maybe I can't exactly get what you're asking for, especially because I never used mbed, but as far as I can see the MbedI2C class is defined on ArduinoCore-mbed/libraries/Wire/Wire.h you linked at first (and I think you already load), so what @UKHeliBob suggested before (give MbedI2C(6,7); a try) seems legit. What am I missing?
With this line of code you posted what I was asking for.
I was speculating if using MbedI2C(6,7); would work.
@UKHeliBob answered "give it a try"
Well I gave it a try by installing a second portable Arduino 1.8.19 ide and tried to compile the I2C-scanner-sketch without any modification.
Compilation aborted with an error-message.
Me personal I am done with the RP2040-mbed-core. I will NOT use the mbed-core.
You seem to prefer the Earl Phillhower-core too.
Well, without knowing the specific error it's hard to tell something.
Anyway, I'm not an expert about this topic so I now stop replying especially if you solved it using that Earl Phillhower-core. Good coding!
What I have done is to create a new TwoWire (arduino::MbedI2C) object as follows:
TwoWire myI2C(SDA_PIN,SCL_PIN);
Then in setup() it needs to be started:
myI2C.begin();
and lastly, you need to pass which I2C device to use to your device's object
Adafruit_GPS GPS(&myI2C);
if it takes it in the constructor or
mydevice.begin(&myI2C)
if the library you are using has a begin function that can take a different I2C device as an argument.
