Hi, i'm currently doing a PID controller for 3 motors, when I applied seperately, the result was quite acceptable, however, when combining them to one code, the noise oscillated really fast (I don't know how to say it right).
This is the result of one motor at a time (motor 2):
And this is the result of the combining (result of motor 2 only):
Is it possible if to much code slow down the process, I only use TimerOne to make the attachInterrupt for the PID every 0.01s, and the PWM pins are not 11, 12 which are related to TimerOne.
Here is the code I use:
#include <TimerOne.h>
#include <SoftwareSerial.h>
SoftwareSerial bluetooth(50,52);
// Động cơ 1 - thay đổi theo bảng xanh
#define ENA 5
#define IN11 31
#define IN12 33
#define ENCA 20
#define ENCB 21
// Động cơ 2
#define ENA2 7
#define IN21 28
#define IN22 29
#define ENCA2 18
#define ENCB2 19
// Động cơ 3
#define ENA3 8
#define IN31 25
#define IN32 23
#define ENCA3 2
#define ENCB3 3
char docgiatri = 's';
#define PPR 480
#define vtt 130
double T;
double tocdo1 = 0; double xung1 = 0; double tocdodat1;
double tocdo3 = 0; double xung2 = 0; double tocdodat2;
double tocdo2 = 0; double xung3 = 0; double tocdodat3;
// PID động cơ 1
double Output1= 0; double LastOutput1 = 0;
double E_1, E1_1, E2_1;
double a_1, b_1, g_1, kp_1, ki_1, kd_1;
// PID động cơ 2
double Output2= 0; double LastOutput2 = 0;
double E_2, E1_2, E2_2;
double a_2, b_2, g_2, kp_2, ki_2, kd_2;
// PID động cơ 3
double Output3= 0; double LastOutput3 = 0;
double E_3, E1_3, E2_3;
double a_3, b_3, g_3, kp_3, ki_3, kd_3;
void follow_angle(int goc)
float goc_rad = goc*PI/180.0;
tocdodat1 = int(((2.0/3) * cos(goc_rad)) * vtt);
void demxung1()
if (digitalRead(ENCB) == LOW) xung1++;
else xung1--;
void demxung2()
if (digitalRead(ENCB2) == LOW) xung2++;
else xung2--;
void demxung3()
if (digitalRead(ENCB3) == LOW) xung3++;
else xung3--;
void PID_controller()
// double present = millis();
a_1 = 2*T*kp_1 + T*T*ki_1 + 2*kd_1;
b_1 = T*T*ki_1 - 4*kd_1 - 2*T*kp_1;
g_1 = 2*kd_1;
a_2 = 2*T*kp_2 + T*T*ki_2 + 2*kd_2;
b_2 = T*T*ki_2 - 4*kd_2 - 2*T*kp_2;
g_2 = 2*kd_2;
a_3 = 2*T*kp_3 + T*T*ki_3 + 2*kd_3;
b_3 = T*T*ki_3 - 4*kd_3 - 2*T*kp_3;
g_3 = 2*kd_3;
tocdo1 = ( abs((xung1/480.0) * (1/T)* 60));
tocdo2 = ( abs((xung2/480.0) * (1/T)* 60));
tocdo3 = ( abs((xung3/480.0) * (1/T)* 60));
xung1 = 0; xung2 = 0; xung3 = 0;
E_1 = tocdodat1 - tocdo1;
E_2 = tocdodat2 - tocdo2;
E_3 = tocdodat3 - tocdo3;
Output1 = (a_1*E_1 + b_1*E1_1 + g_1*E2_1 + 2*T*LastOutput1)/(2.0*T);
Output2 = (a_2*E_2 + b_2*E1_2 + g_2*E2_2 + 2*T*LastOutput2)/(2.0*T);
Output3 = (a_3*E_3 + b_3*E1_3 + g_3*E2_3 + 2*T*LastOutput3)/(2.0*T);
if (Output1 > 255) Output1 = 255;
else if (Output1 < 0) Output1 = 0;
if (Output2 > 255) Output2 = 255;
else if (Output2 < 0) Output2 = 0;
if (Output3 > 255) Output3 = 255;
else if (Output3 < 0) Output3 = 0;
LastOutput1 = Output1;
E2_1 = E1_1;
E1_1 = E_1;
LastOutput2 = Output2;
E2_2 = E1_2;
E1_2 = E_2;
LastOutput3 = Output3;
E2_3 = E1_3;
E1_3 = E_3;
pinMode(ENCA, INPUT_PULLUP);
pinMode(ENCB, INPUT_PULLUP);
pinMode(ENA,OUTPUT);
pinMode(IN11,OUTPUT);
pinMode(IN12,OUTPUT);
pinMode(ENCA2, INPUT_PULLUP);
pinMode(ENCB2, INPUT_PULLUP);
pinMode(ENA2,OUTPUT);
pinMode(IN21,OUTPUT);
pinMode(IN22,OUTPUT);
pinMode(ENCA3, INPUT_PULLUP);
pinMode(ENCB3, INPUT_PULLUP);
pinMode(ENA3,OUTPUT);
pinMode(IN31,OUTPUT);
pinMode(IN32,OUTPUT);
attachInterrupt(digitalPinToInterrupt(ENCA), demxung1, FALLING);
attachInterrupt(digitalPinToInterrupt(ENCA2), demxung2, FALLING);
attachInterrupt(digitalPinToInterrupt(ENCA3), demxung3, FALLING);
TCCR1B = TCCR1B & 0b11111000 | 1;
T = 0.01;
// kp_1 = 2.42; ki_1 = 2; kd_1 = 0;
kp_1 = 1.51; ki_1 = 0; kd_1 = 0;
// kp_2 = 2.01; ki_2 = 1.8; kd_2 = 0;
kp_2 = 4; ki_2 = 6.47; kd_2 = 0;
// kp_3 = 1.8; ki_3 = 1.8; kd_3 = 0;
kp_3 = 1.51; ki_3 = 0; kd_3 = 0;
bluetooth.begin(9600);
Timer1.initialize(5000);
Timer1.attachInterrupt(PID_controller);
if (bluetooth.available() > 0) docgiatri = bluetooth.read();
Serial.print(tocdodat2);
Serial.print("\t"); Serial.print (tocdo2); Serial.print("\t"); Serial.println(Output2);
switch (docgiatri)
case 's':
tocdodat1 = 0; tocdodat2 = 0; tocdodat3 = 0;
Output1 = 0; LastOutput1 = 0;
Output2 = 0; LastOutput2 = 0;
Output3 = 0; LastOutput3 = 0;
analogWrite(ENA, Output1); analogWrite(ENA2, Output2); analogWrite(ENA3, Output3);
digitalWrite(IN11, 0); digitalWrite(IN12, 0);
digitalWrite(IN21, 0); digitalWrite(IN22, 0);
digitalWrite(IN31, 0); digitalWrite(IN32, 0);
// pause = millis();
case 'd':
tocdodat1 = 100; tocdodat2 = 50; tocdodat3 = 50;
digitalWrite(IN11, 1); digitalWrite(IN12, 0);
digitalWrite(IN21, 1); digitalWrite(IN22, 0); // Do bị ngược dây
digitalWrite(IN31, 1); digitalWrite(IN32, 0); // Do bị ngược dây
case 'a':
// analogWrite(ENA, 88); analogWrite(ENA2, 100); analogWrite(ENA3, 100);
digitalWrite(IN11, 0); digitalWrite(IN12, 1);
digitalWrite(IN21, 0); digitalWrite(IN22, 1); // Do bị ngược dây
digitalWrite(IN31, 0); digitalWrite(IN32, 1); // Do bị ngược dây
case 'w':
tocdodat1 = 0; tocdodat2 = 100; tocdodat3 = 100;
case 'x':
// case '3':
// tocdodat1 = 50;
// analogWrite(ENA, Output1);
// digitalWrite(IN11, 0); digitalWrite(IN12, 1);
// break;
// case '4':
// tocdodat1 = 50;
// analogWrite(ENA, (Output1));
// digitalWrite(IN11, 1); digitalWrite(IN12, 0);
// break;
// case '0':
// tocdodat1 = 100;
// break;
case '9': //
case '0': //
Thank you very much!!!
