hi, i am using pin 1 and 17 as output, but the state doent change, i need this pin because i have many outputs, could somebody help me?
thanks a lot!!!!
thanks a lot!!!!
Looks like you have the other side of the LEDs connected to GND.
If you expect a LOW signal to light the LED then you need to have the LEDs connected to 3.3/5v.
Otherwise a HIGH signal is required to light the LED.
Also make sure the LEDs are the correct way around.
You cannot use GPIO_NUM_1, under the Arduino IDE, as an output. That is one of the programing port pins.
i reviewed and that is ok ![]()
do not use
pins 0,1,2,3
pins 6 - 11 are used to program internal flash and are usually not made available.
pin 35 is battery voltage - do not use, research what it does
pins 32 and 33 may be output only.
pins 34, 36 and 39 are input only.
