Hello,
I am trying to implement the pin change interrupt for reading the PWM signal. I started from the example on this webpage. Here's the code:
#include <PinChangeInt.h>
#define MY_PIN 5 // we could choose any pin
volatile int pwm_value = 0;
volatile int prev_time = 0;
uint8_t latest_interrupted_pin;
void rising()
latest_interrupted_pin=PCintPort::arduinoPin;
PCintPort::attachInterrupt(latest_interrupted_pin, &falling, FALLING);
prev_time = micros();
void falling() {
PCintPort::attachInterrupt(latest_interrupted_pin, &rising, RISING);
pwm_value = micros()-prev_time;
// Serial.println(state);
Serial.println("pwm_value");
pinMode(MY_PIN, INPUT); digitalWrite(MY_PIN, HIGH);
PCintPort::attachInterrupt(MY_PIN, &rising, RISING);
void loop() { }
When compiled on Arduino Uno, the code works. However, the code does not compile on Attiny85 - it complains about the PCintPort command. Is there a simple way to solve this problem? Maybe another library that works better? I need the pin change interrupt since the only external interrupt pin of Attiny85 is used for another purpose.
That library is so old, the example sketches still have the .pde extension! I would try the PinChangeInterrupt library which you can install from the IDE Library Manager (Tools->Manage libraries...).
Here is your sketch modified for the newer library, I don't know if it will work on an ATtiny85 but it does compile without error using the ATtinyCore.
#include <PinChangeInterrupt.h>
volatile int rising_time = 0;
void rising()
attachInterrupt(MY_PIN, &falling, FALLING);
rising_time = micros();
void falling()
attachPinChangeInterrupt(MY_PIN, &rising, RISING);
pwm_value = micros() - rising_time;
void loop() { }
Thank you!
I will test this code tomorrow. I modified it slightly, in order to calculate the off-time and the duty cycle:
volatile float pwm_on_value = 0;
volatile float pwm_off_value = 0;
volatile float duty_cycle = 0;
volatile int falling_time = 0;
void rising()
pwm_off_value = prev_time - falling_time;
Serial.print("pwm_off_value = ");
Serial.println(pwm_off_value);
void falling()
pwm_on_value = micros() - rising_time;
Serial.print("pwm_on_value = ");
Serial.println(pwm_on_value);
falling_time = micros();
duty_cycle = pwm_on_value * (1.0/(pwm_on_value + pwm_off_value));
Serial.print("duty cycle = ");
Serial.println(duty_cycle);
void loop() { }
Not sure whether I calculate the off-time and the duty cycle correctly.
