This is my code without touch sensor. Can help me someone with a code with touch sensor(when press touch sensor alarm stops)????
#include <LiquidCrystal.h>
int ledPin = 13; // choose the pin for the LED
int led1 = 8;
int led2 = 9;
int led3 = 6;
int inputPin = 7; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
int pinSpeaker = 10; //Set up a speaker on a PWM pin (digital 9, 10, or 11)
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // initialize the library with the numbers of the interface pins
void setup() { pinMode(ledPin, OUTPUT); // declare LED as output pinMode(inputPin, INPUT); // declare sensor as input
pinMode(pinSpeaker, OUTPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
digitalWrite(led3, LOW);
digitalWrite(led1, LOW);
digitalWrite(led2, HIGH);
delay(80);
lcd.begin(16, 2);
lcd.setCursor(2, 0); // Set LCD cursor position (column, row)
lcd.print("P.I.R Motion"); // Print text to LCD
lcd.setCursor(5, 1); // Set LCD cursor position (column,row)
lcd.print("Sensor"); // Print text to LCD
delay(4000); // wait 4s // Delay to read text
lcd.clear(); // clear LCD display // Clear the display
lcd.print("Developed By"); // Print text to LCD
lcd.setCursor(2, 1); // Set LCD cursor position (column, row)
lcd.print(" Serafim"); // Print text to LCD
delay(5000); // Delay to read text
lcd.clear(); // Clear LCD
lcd.setCursor(0, 0);
lcd.print("Processing Data.");
delay(5000);
lcd.clear();
lcd.setCursor(3, 0);
lcd.print("Waiting For");
lcd.setCursor(3, 1);
lcd.print("Motion....");
digitalWrite(led2, LOW);
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
delay(80);
digitalWrite(ledPin, HIGH); // turn LED On
playTone(1500, 10);
digitalWrite(ledPin, LOW);
digitalWrite(led3, HIGH);
playTone(1500, 10);
playTone(1500, 10);
playTone(1500, 10);
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
lcd.clear() ;
lcd.setCursor(0, 0); // Set LCD cursor position (column 0, row 0)
lcd.print("Motion Detected!");
delay(2000);
digitalWrite(led1, HIGH);
// We only want to print on the output change, not state
pirState = HIGH;
digitalWrite(ledPin, LOW); // turn LED OFF
playTone(0, 0);
delay(300);
if (pirState == HIGH){
// we have just turned of
Serial.println("Motion ended!");
lcd.clear() ;
lcd.print("Motion...."); // We only want to print on the output change, not state
pirState = LOW;
// duration in mSecs, frequency in hertz
void playTone(long duration, int freq) {
duration *= 1000;
int period = (1.0 / freq) * 100000;
long elapsed_time = 0;
while (elapsed_time < duration) {
digitalWrite(pinSpeaker,HIGH);
delayMicroseconds(period / 2);
digitalWrite(pinSpeaker, LOW);
elapsed_time += (period);
