PIR Sensor - How do I connect it to the board
I am no electrician and spent only a few hours with my Arduino. Yesterday I just picked up a PIR Sensor and I'm not sure where to start connecting the PIR or any other sensor for that matter. The LED needed a resistor and I'm guessing my answer is somewhere in this description of the PIR quoted below. Thanks for any help, explanation, or smart ars comments.
Key Specifications
? Power Requirements: 3 to 6 VDC; 12 mA @ 3 V, 23 mA @ 5 V
? Communication: Single bit high/low output
? Operating temperature: 32 to 122 °F (0 to 50 °C)
? Dimensions: 1.41 x 1.0 x 0.8 in (35.8 x 25.4 x 20.3 cm)
http://www.parallax.com/Portals/0/Downloads/docs/prod/sens/555-28027-PIRSensor-v2.0.pdf
Ohm's Law
V = IR
Which current(I) and Voltage do I pick from the sensor specs to do the calculation?
What is the spec of the LED you are trying to drive?
It's a motion sensor, the LED was my only point of reference and it needed a resistor. I'm curious how to hook a motion sensor to the Arduino.
Key Specifications
You could power it from the 5V pin, or you could actually power it from an output pin - 23mA is well below the limit of 40mA.
No need for a resistor.
Thanks!
So I connected the PIR to Analogue 0 and to Digital 13 and when I print the value it is 0 even if I wave my hand in front of it. Any ideas?
 *  Motion Detection
int motionPin = 0; //the motion sensor
//  pinMode(ledPin, OUTPUT); //sets the led pin to output
 int motionLevel = analogRead(motionPin); //Read the motionLevel
 Serial.println(motionPin);
Digital not analogue, see the pic and the code
  • Motion Detection
int calibrationTime = 30;
int motionPin = 3; //the motion sensor
pinMode(motionPin, INPUT); //sets the led pin to output
digitalWrite(motionPin, LOW);
Serial.println(digitalRead(motionPin));
What is connected to pin 13?
The PIR?
I don't see where you've turned it on.
The PIR is connected to pin 3. What do you mean by turned it on?
Well, that's about as much confusion as I've seen in two lines of C.
"Supplied it with electrical current"
oops, "//sets the led pin to output" was a cut and paste mistake
I don't think the digitalWrite is necessary - the built-in pullups are disabled by default.
Thanks, I'll try it without.
