hello guys ![]()
currently i have 6 PIR sensors.
is it possible to use 5V from arduino mega pin to power all the sensor? what are the voltage needed to power all the sensor i have?
hello guys ![]()
Excellent you provided use with a type number or a link! Can I now ask you how much fuel I need to drive with 4 cars to Paris? :![]()
But if you mean one like:
They use 5V. And no matter how many you have, they still need 5V :
But maybe you want to know how much current/power they need. They don't need very much so connecting them to the Arduino 5V should be fine.
oh.
that means i can use 5V from arduino to power all 6 PIR sensor? how about the current and power?
i thought the 5V from arduino will be divided by 6 because i got 6 sensor..
PIR based on the BISS0001 don't draw that much power so it's fine on a Arduino.
You connect then parallel so 5V = 5V. Maybe read up on parallel and series circuits.
i connect all the PIR in parallel circuit. it works fine now.
thanks sir. thank you
