Pizza Oven - IR Temperature Sensor / Gas Flow Control
Hello everyone.
Completely new here, also wasn't really aware I could make my pizza oven a "smart pizza oven" until my friend told me Arduino could maybe do that.
So I decided to get some help here before I start getting all the neccessary stuff.
I have a Gas Pizza Oven and I'm about to install a rotating pizza stone this weekend and thought I could extend the "cool stuff" even further.
My goal is to control the gas flow depending on a pizza-stone surface temperature.
I was thinking of following:
  1. IR Sensor checks the pizza stone surface temperature
    2a) If temperature < 480 Degrees Celsius, then full power gas flow
    2b) IF temperature >=480C, lower the gas flow to 50%
  2. Would be cool to get a signal (sound) that the temperature is ready, but isn't a must have.
  3. Also would be cool to display the current temperature on some display, but also not a must have.
Problems:
  1. I couldn't find an IR temperature sensor that's heat/fire resistant and can read temperatures over 450C. Should be able to read up to 600C, since I keep my stone's surface around 500C. MLX90614 goes "only" up to 380C.
  2. Type K thermocouple wouldn't work I guess, since I need a surface temperature and it's gotta be an non-contact sensor.
  3. Which gas flow valve would work? I thought something like THIS could work, but I don't know if that can be controlled via Arduino.
I'm located in Germany if that's important or needed for recommendations.
Also, I've never programmed anything with with/for Arduino, but I guess I'll find enough input online :wink:
Thanks!
I confused, if you already have a means of measuring the temperature, why do you need another?
It's not difficult to find IR sensor that can measure 500'C, but the sensor itself can't handle "oven temperatures". You should install it out from the oven and have IR-window for measurements. I think themocouple on stone surface is easier way to go..
That solenoid valve is on/off, not ideal if you want to regulate gas flow.
I am using something like THIS right now manually and also have to reduce the gas flow manually.
I’d love to do it all automatically.
Also this IR sensor I have now isn’t really heat resistant but can measure above 500C
Can thermocouple really read the stone temperature?
I also can’t really fix the sensor to the stone since the stone is rotating so it’s gotta be a non-contact temperature sensor.
Didn’t notice it was on/off only. Is there anything you can recommend to regulate the flow?
Not an expert in this area but certain glasses like silicon can pass IR.
So you just need to install a small window in your oven and use the sensor outside.
I didn't notice it's rotating....
Ok, it's doable with IR-sensor as well, you just need to find a way to keep the sensor within it's operating temp. I used economic ZnSe lens for my thermal imager. But I don't know how good solution it would be with fumes...
Maybe some "hole" for IR-measurements with little bit air assistance.
For the valve you can use motorized ball valves, commonly available and not too expensive.
I can make a hole and use the sensor outside. It's only important that it can measure the temperature.
Can you suggest me a sensor? As I've said, up to 600C is enough since I try to keep the stone at 480-490C, but sometimes I forget about it for 2-3 minutes and its already at 550C, so it's gotta go to 600C just to be sure.
I could make a hole and measure it from outside, yeah.
Do you have a recommendation for an IR sensor to measure the temp from the outside?
Thanks for your imput about motorized ball valves.
I didn't even know how such stuff is called so it's a good info to start looking.
Is there anything I have to pay attention for? Or are all of them compatible with arduino?
Never used one. Had a quick look. Hobby modules have a range up to 380'C, "professional" sensors that go above 500'C are costing >50eur even in AE. But at the same time you can find ready made thermometers that are advertised to go above 500'C for ~10eur... I wonder what they really have inside...
Be aware that the sensor has quite wide opening, not like the laser beam it outputs for targeting.
https://aliexpress.com/item/32736750087.html
If you already have manual regulator for gas flow, you could mount a servo on that knob. Easy and safe.
If you go with ready made motor valve, make sure your connections are 100% gas proof.
They are usually 12-24V valves so you need some simple circuit to operate it with arduino.
Thanks!
I dont mind paying a bit more for a good temp sensor which is going to work with arduino.
I'll check the servo too! I have a manual regulator now, yeah so that might be a "cheaper" (?) solution.
And yeah, safety first so making sure everything is gas proof and other stuff is priority.
Thanks once again!
Unless your oven operates with a pilot light, you need to coordinate the igniter circuit with your gas control!
I hope you live in a third world country.
Most countries have strict gas regulations, where no electronics is allowed near untested gas appliances.
Also think of your house and medical insurance, which will become non-existant.
Leo..
