Platform arduino
hi my name is iulian im don’t know i go in crazy because im buyed all in time board for develope i like develope 1 project im asked help peolpe but all can’t help me for my parent’s im asking in this place for develope a hobby object how much more buy a baord develope?? when buy board all board is egual and the sensor i don’t very well and on marketpalce stay more sensor . in the time i buyed board development but the my project is not complete thank for help me
Your topic does not seem to indicate a problem with IDE 2.x and therefore has been moved to a more suitable location on the forum.
Your topic is difficult to read. It also does not contain information that might help us to help you.
  1. What do you want to develop?
  2. What have you already bought for it (if anything)?
  3. Which problems are you encountering?
I doubt English is your native language. I would like to suggest that you write your messages in you native language, use e.g. google translate to translate it and next post the translation here.
Please do not ask your questions multiple times on the forum. It wastes peoples time.
hello with translator I excused myself and I find so many problems
1 you want to develop a handpan with 10 non-so piezo or digital sensors, I developed 50% of the project, it doesn't work well because the sensors are debounce, so I have a better result
2 ho arduino uno r3 arduino uno r4 arduino hat carrier portenta portenta h7 portenta ai etc
3 sensors piezo sensors or sensors ttp33b
4 I find a lot of problems with sensor boards and cables, I bought arduino uno r3 a few years ago, I thought that I made the right choice, but arduino uno r4 will be fine, not 100%, maybe 30% because the sensors are not stable, I bought it 1 week ago, arduino portenta suffering from resolver but other problems, because uavo and ttp223b have 3 pins, instead, portenta breakout has 2, I have to buy other sensors, etc. a 100% functional finished object without any other similar problems I am a student and I would just like to complete my project thanks.
Ciao, l'ho fatto con un traduttore. Mi dispiace, ma sto riscontrando molti problemi.
  1. Vorrei sviluppare un handpan con 10 sensori. Non so se sono piezoelettrici o digitali. Sono al 50% del progetto. Il progetto non funziona bene perché i sensori vanno in debounced. Non so come ottenere un risultato migliore.
  2. Ho Arduino Uno R3, Arduino Uno R4, Arduino HAT Carrier, Portenta, Portenta H7, Portenta AI, ecc.
3 sensori: sensori piezoelettrici o sensori TTP33B.
  1. Ho molti problemi con le schede e i cavi dei sensori. Ho comprato Arduino Uno R3 anni fa, pensando che fosse la scelta giusta, ma niente. Poi Arduino Uno R4 funziona bene. Non al 100%, forse al 30%, perché i sensori non sono stabili. Ho acquistato Arduino Portenta una settimana fa, ma ho difficoltà a risolverlo. Ma ho altri problemi perché ho usato i TTP223B, che hanno 3 pin, mentre il breakout Portenta ne ha 2. Devo comprare altri sensori, ecc. La mia domanda è la stessa di prima: quante altre schede devo comprare per avere un oggetto finito che funzioni? Nessun problema di debouce o simili. Sono uno studente e vorrei solo completare il mio progetto, grazie.
Draw a picture of your project and post the picture here.
You want to create the musical instrument....
Using Piezo sensors...
Maybe you need "touch sensors" (ttp223b) if the "vibration sensors" are too sensitive...
Maybe something like this... each tone field has a touch/tap sensor...
You will need a resistor for the Piezo sensor.
https://docs.arduino.cc/built-in-examples/sensors/Knock/
You only need the module for the touch sensor.
Il forum ha alcune categorie in italiano (vedi Italiano - Arduino Forum). Potrebbe essere molto più facile per te (e per gli altri) se pubblicassi la tua domanda nella tua lingua madre, probabilmente su Generale - Arduino Forum.
Assicurati di presentarti per primo!
Facci sapere quando lo hai fatto, così possiamo bloccare la discussione.
The forum has a few Italian categories (see Italiano - Arduino Forum). It might be a lot easier for you (and others) if you post your question in your native language there, probably in Generale - Arduino Forum.
Make sure that you introduce yourself first!
Let us know when you have done that so this topic can be locked.
I think we extracted enough information to find the goal. OP is now figuring the details.
That design will not work. The reason is that the each tap sensor will interfere with the other.
I made this hang bell but using a different design. Basically I used touch sensors on brass plates, along with LEDs.
Yes this was for the Raspberry Pi, but there is no reason why you should not take the design and implement it with an Arduino.
This is my son playing it after only a few minuets practicing.
Notice you can also use it to get different sounds, in this case bells and Drums. It is just a matter of software.
