UM, THIS works
Streaming of sound data with Bluetooth to other Bluetooth device.
We generate 2 tones which will be sent to the 2 channels.
Copyright (C) 2020 Phil Schatzmann
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
#include "BluetoothA2DPSource.h"
#include <math.h>
#define c3_frequency 500
BluetoothA2DPSource a2dp_source;
// The supported audio codec in ESP32 A2DP is SBC. SBC audio stream is encoded
// from PCM data normally formatted as 44.1kHz sampling rate, two-channel 16-bit sample data
int32_t get_data_frames(Frame *frame, int32_t frame_count) {
static float m_time = 0.0;
float m_amplitude = 10000.0; // -32,768 to 32,767
float m_deltaTime = 1.0 / 44100.0;
float m_phase = 0.0;
float pi_2 = PI * 2.0;
// fill the channel data
for (int sample = 0; sample < frame_count; ++sample) {
float angle = pi_2 * c3_frequency * m_time + m_phase;
frame[sample].channel1 = m_amplitude * sin(angle);
frame[sample].channel2 = frame[sample].channel1;
m_time += m_deltaTime;
// to prevent watchdog
delay(1);
return frame_count;
a2dp_source.set_auto_reconnect(false);
a2dp_source.set_data_callback_in_frames(get_data_frames);
a2dp_source.set_volume(30);
a2dp_source.start("JBL TUNE500BT");
// to prevent watchdog in release > 1.0.6
hello, so this is a code where the esp32 connect to my JBL headphones and it produces a 500hz noise and it works. Now I tried using an SD card to play real music from the esp32 but got many problems and barriers. Does anyone have the solution to import just the perfect logics or libraries to somehow convert the MP3 or WAV music from the SD card to some data that can be sent from the esp32 to my headphones?
thank you ![]()
