"C:\Users\Guest01\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\8.0-arduino.1/bin/avrdude" "-CC:\Users\Guest01\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\8.0-arduino.1/etc/avrdude.conf" -v -patmega8 -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0xff:m -Uefuse:w:{bootloader.extended_fuses}:m -Uhfuse:w:0b11010111:m -Ulfuse:w:0b10100100:m
Avrdude version 8.0-arduino.1
Copyright see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
System wide configuration file is C:\Users\Guest01\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\8.0-arduino.1\etc\avrdude.conf
Using port : COM7
Using programmer : stk500v1
Setting baud rate : 19200
AVR part : ATmega8
Programming modes : SPM, ISP, HVPP
Programmer type : STK500
Description : Atmel STK500 v1
HW Version : 2
FW Version : 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.0 us
XTAL frequency : 7.372800 MHz
AVR device initialized and ready to accept instructions
Device signature = 00 00 00 (retrying)
Error: invalid device signature
Error: expected signature for ATmega8 is 1E 93 07
- double check connections and try again, or use -F to carry on regardless
Avrdude done. Thank you.
Failed chip erase: uploading error: exit status 1
What's an ATMEGA8? Looks like a 168 on the virtual Protoboard, is that what you meant?
A few more discrete parts are required for an ATmega8 chip to run, and be programmable. Tutorial
No decoupling caps?
No crystal (or associated caps)?
No pullup on target /RESET?
(Possibly) No 10uF on programmer /RESET?
Take a look at this, it might help you...
