What done with this cheap clone of arduino Nano before:
Flash optiboot bootloader, just by flashing UNO bootloader through Arduino IDE to free some extra flash memory. I use Arduino UNO R3 clone as ISP programmer.
Continue use ISCP to load sketches, all been ok for 50 times or more.
Last time, when i try to load sketch something gone wrong, and process freezes. After waiting few minutes, i just unplugged USB-cable from UNO.
After reconnect cable to UNO, i can't anymore flash anything to Nano (tried flash "blink" and bootloader).
Log of trying to flash "blink" through Arduino UNO R3 as ISP to Nano
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "E:\arduino\arduino-1.8.5-windows\arduino-1.8.5\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM9
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
trying flash bootloader
nf -P com9 -b 19200 -c stk500v1 -p m328p -v
Using Port : com9
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
W ReadBack
00 0xff 0xff
00 0xff 0xff
00 0x00 0x00
00 0x00 0x00
00 0x00 0x00
00 0x00 0x00
0 0x00 0x00
0 0x00 0x00
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Reading | ################################################## | 100% 0.06s
Reading | ################################################## | 100% 0.04s
this check.
I've also tried to flash on UNO Atmega_Board_Detector from here GitHub - nickgammon/arduino_sketches: Publicly-released sketches for the Arduino microprocessor
After connect to nano's ISCP and connect UNO to PC, get in serial monitor "Failed to enter programming mode. Double-check wiring!"
If i connect nano through USB, Power led is up, "L' led don't flash 3 times after reset like on UNO.
"Loopback test" (reset to GND, TX to RX, connect to PC through USB) - try send something in serial monitor: - RX blinks, TX blinks by i don't get "echo" in serial monitor
Also, i check all wires by multimeter, all ok.
What also i can try? I Just run out of ideas.
