when I it connect directly to LiIon I get 2.99 Volts for two seconds when exist motion (shake hand)
Vcc on my scheme - it is multimetr its show me 2.99V so sensor is working and I get High level for motion
But, when I create sketch and connect sensor to interrupt pin nothing happen
when I check Volts I get only 0.2 volts from sensor.
and when I directly connect interrupt pin with Vcc line I get on serial monitor my text, so interrupts is working, but cannot understand why sensor is not sending 2.9Volts to arduino
please help troubleshoot
I tried. as was described above . pir w/o MC returns 2.9V
interrupt also is worked w/o PIR
so... I have connected (initial) pin 4 as pull down. as it should be if we want to catch rising edge. but I dont know why this doesnt work
after that I have connected Vout from PIR direct to pin3 and its working now
hm....
tried now with pin change interrupt on digital pin 11. the same shit
when pin is pull down and Vout from sensor goes to this pin then interrupt is not fired.
if Vout goes directly to pin 11 (and pin 11 doesnt have pull down) then interrupt is working
