Hi All,
I'm very close to giving up on my project after 3 months of trying to figure this out, I know it's not that hard but I have no idea what I am doing.
I have attached photos.
I want to be able to send MIDI data from my DAW to the Arduino then have it trigger 2 solenoids to hit a hi-hat, and also to control a servo that opens/closes it, or controlled by one of the potentiometers. I preferably want control over velocity too. I also want the 6 potentiometers to be able to act as macro knobs to control DAW functions of my choosing, probably a sequencer. Hardware wise it is all finished. The solenoids are on D3 and D5, the Servo is on D2. Pots on 0-5 inputs.
I managed to use the Ableton connection kit for Arduino, and was able to use the knobs as macro, and trigger the solenoids but only with key triggers, or as macro, I couldn't send any midi notes. I realise I need to use the IAC driver, and have figured that out. I have tried hairless MIDI, MIDIbus, processing etc. etc. But I have no idea how to even code or anything, I tried some examples, but don't understand what to change or if i can combine things together.
I would consider paying someone to just do this for me at this stage so I can just paste the code into my Arduino and finally finish this.
I appreciate any help given,
Thanks,
Sadamo
