I really need your help/ midi controler mega 2560 ch340g
I'm really new on this and I just want to make a cheap midi pedalboard, I thought that the arduino mega would work for me since it has many digital pins, and it would be perfect for all the buttons that I want to use, I saw a tutorial where they used it but when it came time to buy I didn't realize that I chose the arduino CH340g, which When it came time to do the DFU I realized that I didn't have the pins to do it, I saw that there is an alternative using hairless but I'm not really sure how to do it and I'm not sure if the code that chatGPT gave me works for it. use it, when using other codes that I find on the internet it gives me many errors
// Potenciómetros conectados a A0 a A9
const int potPins[] = {A0, A1, A2, A3, A4, A5, A6, A7, A8, A9};
// Interruptores DPDT conectados a pines 2 a 9
const int dpdtPins[] = {2, 3, 4, 5, 6, 7, 8, 9};
// Footswitches 3PDT conectados a pines 22 a 30
const int switchPins[] = {22, 23, 24, 25, 26, 27, 28, 29, 30};
// LEDs de los footswitches conectados a pines 31 a 39
const int ledPins[] = {31, 32, 33, 34, 35, 36, 37, 38, 39};
  Serial.begin(115200);  // Iniciar comunicación serial
  // Configurar pines de los potenciómetros como entradas
  for (int i = 0; i < 10; i++) {
    pinMode(potPins[i], INPUT);
  // Configurar pines de los interruptores DPDT como entradas
  for (int i = 0; i < 8; i++) {
    pinMode(dpdtPins[i], INPUT_PULLUP);  // Usar resistencias pull-up internas
  // Configurar pines de los footswitches 3PDT como entradas
  for (int i = 0; i < 9; i++) {
    pinMode(switchPins[i], INPUT_PULLUP);  // Usar resistencias pull-up internas
    pinMode(ledPins[i], OUTPUT);  // Configurar los pines de los LEDs como salidas
    digitalWrite(ledPins[i], LOW);  // Apagar los LEDs al inicio
  // Leer los valores de los potenciómetros y enviar como Control Change en MIDI
    int potValue = analogRead(potPins[i]);
    sendControlChange(i, potValue / 8);  // Los valores de los potenciómetros van de 0 a 127 en MIDI
  // Leer los interruptores DPDT y enviar mensajes MIDI de Control Change (ejemplo)
    int dpdtState = digitalRead(dpdtPins[i]);
    if (dpdtState == LOW) {
      sendControlChange(i + 10, 127);  // Activar el control MIDI
      sendControlChange(i + 10, 0);  // Desactivar el control MIDI
  // Leer los footswitches 3PDT y controlar los LEDs
    int switchState = digitalRead(switchPins[i]);
    if (switchState == LOW) {  // Footswitch presionado
      digitalWrite(ledPins[i], HIGH);  // Enciende el LED
      sendControlChange(i + 18, 127);  // Enviar señal MIDI de control
      digitalWrite(ledPins[i], LOW);  // Apaga el LED
      sendControlChange(i + 18, 0);  // Apagar el control MIDI
  delay(10);  // Pequeña pausa para evitar saturar el bus MIDI
// Función para enviar un mensaje MIDI de Control Change
void sendControlChange(int controlNumber, int value) {
  Serial.write(0xB0);  // Mensaje de Control Change en el canal 1
  Serial.write(controlNumber);
  Serial.write(value);
MIDI works at 31250 bps, you will never be able to communicate at 115200 bps.
On the other hand, the CH340 offers no impediment to MIDI communication.
Yes but an Arduino Mega can't produce anything except a MIDI signal of the 5 Pin DIN type. In order to produce a MIDI signal that looks like a MIDI signal to another computer you must use a helper application, such as Hairless. This, I understand, still works on windows but not on Macs past OS 10.14.6.
We will never know unless you post the code, but it is unlikely that it could.
You might want to look at this How to get the best out of this forum before you proceed any further.
We only know what you tell us, and without knowing what you have, we don't stand a chance.
