I tried searching the forums for this but there are so many threads that have the words solder and board in them, I couldn't read through them all.
I'm ready to move my project off of the solder-less breadboard and solder it permanently in place. Can you recommend a small ready to solder board with eyelets already in it? Preferably available from sellers in the U.S.
BlueJakester:
Do you need for it to plug into an Arduino board, the way an off-the-shelf shield would? If so, there are many "proto-shield" products around, for example from Adafruit or Sparkfun.
Or do you want to recreate the Uno and your added parts?
For example, here is the equivalent of a Promini using a DIP (lower left corner), with my added parts. Runs from external 5V source, so no regulator used.
Thank you for the feedback gentlemen. CrossRoads, what a cool board! Thanks for the pic.
I'm a new user of the Arduino Uno (R3). I purchased an Inventors Kit from SparkFun a couple of weeks ago and have had a lot of fun learning. I also purchased an Arduino Ethernet Shield about a week ago to get my Uno onto the network. The Ethernet Shield's microSD card made for a nice bonus.
I ended up building a really simple temperature taking circuit, I log the readings to the SD card along with a time-stamp, and make the readings retrievable via http calls to the "Server." There are also a few flashing LEDs to indicate various activities.
The project is truly nothing special, but I put a lot of work into the coding (all of it re-usable for future projects) and decided to solder up the circuit should I want to run it again in the future. It's like a first pet
So I'm not looking to turn the circuit into a shield. I just wanted an easy to solder on board to make it permanent.
If you want to transfer from breadboard to stripboard and don't want to re-design the circuit then this company does stripboard with breadboard layouts Home | BusBoard Prototype Systems
Vero is another good source of prototyping products http://www.verodirect.com/
Riva:
Thanks Riva. These look perfect for my project and very easy for a novice to work with.
