avr_fred:
Yes, it has already been done, and well too. I've found these pro-mini specific proto boards from one of our regular contributors here to be a real time saver:
https://www.tindie.com/products/DrAzzy/project-board-for-arduino-pro-mini-/
While it may be a dollar more than a blank board, it will pay for itself many times over in the time saved when it comes to mounting and wiring all the typical parts you'll want in addition to the pro-mini. Dr Azzy's stuff is very well thought out and of good quality. Highly recommended.
That's a pretty impressive board. It's a bit more capable than I really need, but the price is decent. I'm not into surface mount parts, but I know plenty of people are. If they just made an SB300 type board with a wider stance, it'd be perfect for me.
I don't mind soldering the board down as long as I can still flash it in circuit. This brings up a noob type question. Is there a tutorial explaining what I need to know and observe when it comes to flashing the board in circuit where the board will already have a 5V regulated supply available? I'm wondering if I should disable that power and power the board through the horizontal pins that you flash it with, or just leave the Vcc pin on the flash header disconnected from the USB to serial adapter and leave the other power applied. In case you can't tell, I haven't touched this stuff for a few years now and I've forgotten a lot of these kinds of details.
Basically, what I'm doing is using the Arduino to handle a bunch of pushbuttons and then when the user puts in the correct sequence, I'll drive an output pin high that goes to the base of a 2n4401 transistor that enables a 12V automotive relay. The relay will have a protection diode added to prevent spiking the collector of the transistor when it turns off.
All I have available is a 12V DC supply coming into the cabinet. I was thinking of using a 7805 regulator on the board to create the 5V supply I need for the Arduino. I'm a little leery of connecting the 12V supply directly to the RAW input of the Arduino, should I be? I mean I know that the "official" pro mini is supposed to tolerate 16V, but my boards are made by Inland (Micro Center purchase) and I'm unsure if their regulator is okay with that much voltage, they only specify up to 12V. Of course a 12V wall wart tends to run a little above that, and I'm always one to treat maximum specs as something you should never reach, much less exceed, even if it is just a tiny amount.
If I feed a regulated 5V into the Vcc pin, can that harm the onboard regulator if nothing is connected to RAW pin? A 7805 can suffer greatly from doing something like that, so I'd rather not have to include my own regulator if I don't need to. I guess I should just try feeding 12V into the RAW pin of one of my boards and see what happens.
Here is the board I'm using:
http://www.microcenter.com/product/431996/arduino_pro_mini_board
