sven-e
September 23, 2022, 8:03pm
1
Hi, Using the new plotter I can only see about 50 samples (horisontally) The old v1 plotter showed many more samples. I cannot find a setting or preference to allow more samples in the plotter window.
It would be nice to have a setting to to adjust how many samples to be included in the plotter window.
FYI: I have an application that outputs 10 samples every second. This means that the plotter window only covers 5 seconds. This is too short to show how the application works. I need at least 30 seconds.
(Sending this bug report here as I could not find a better place. If there is, please let me know.)
Thanks / Sven
Hi @sven-e . Thanks for your suggestion. The Arduino IDE developers are tracking this here:
opened 07:47PM - 02 Feb 22 UTC
type: enhancement
topic: code
**Is your feature request related to a problem? Please describe.**
The new Se… rial Plotter displays only 50 data values, compared to the previous version, which displayed 500 values.
This is a problem because events stream by 10 times faster and are much harder to see. With 500 points we see a much clearer time history of the physical measurements we're making. I use the Plotter a lot in my K-12 STEM workshops, and this will really have a negative impact.
**Describe the solution you'd like**
Change the number of plot values back to 500. Or make it a user selectable option
**Describe alternatives you've considered**
I can modify my old programs to slow Serial.print outputs so the data stream doesn't disappear so quickly. It kinda works but it's suboptimal.
and here:
opened 09:53AM - 24 Mar 22 UTC
type: enhancement
topic: code
### Describe the request
Adding some setting to Serial Plotter:
- A button to… to disable the auto-scale
- A zoom to have more points in the x-axis
### Describe the current behavior
The auto-scale do not allow me to have a good and rapid reading of the graph evolution. The too low number of points in x-axis does not allow me to have a view of the high speed datas for a long enough time.
### Arduino IDE version
2.0.0-rc5
### Operating system
Windows
### Operating system version
10 Pro x64 (20H2)
### Additional context
_No response_
### Issue checklist
- [X] I searched for previous requests in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the feature was still missing when using the latest [nightly build](https://github.com/arduino/arduino-ide#nightly-builds)
- [X] My request contains all necessary details
If you have a GitHub account, you can subscribe to that issue to get notifications of any new developments related to this subject.
In the meantime you can alias your display by display every nth point. The user may not need that much information.
DR
