Pn2222 Transistor as Switch for my coffe machine ESP8266
Hello,
i want to use a Pn2222 Transistor to simulate a button. I have a old coffe machine and i want to add a esp8266 (controlling with my amazon echo). My electronic knowledge is not that good but i have a lot of free time while corona.
On the coffemachine there are a few buttons with 4 pins. I can messure 1,2V on upper left and bottom left to Ground. Upper right and bottom right i can messure 4,8V to Vcc
I conntected collector with bottom left and emitter with bottom right.
When i talke to my echo "coffe machine on" i hear a noice but the machine dont start.
Thanks for your time.
Before connecting a transistor, use a piece of wire to connect the pins, to simulate a button press on the machine.
When you find a working connection, then you can proceed with a transistor.
Or connect 4 wires to the pins, and measure their levels when a button is pressed and not pressed.
Hey thanks for your answer,
if i conntect green and orange(bottom right) or blue with orange(bottom right) -> machine turn off/on
Therefore it should be correct (first picture). I dont know whats wrong?
Ok now a test with 5V (not Gpio output)
green and blue to 1 - Collector
5V - 2 - Base
Orange and Orange to 3 - Emitter
i get the same result. When i connect 5V to Base i can hear a beeper but not more. Maybe my problem is time? Sometimes randomly the machine goes on/off but thats not my goal.
A transistor can be used as a switch in certain applications but it's NOT the same as a mechanical switch.
However a regular electro-mechanical RELAY IS and electrically-operated and electrically-isolated switch. A relay is almost always better if you want to replace a switch in an unknown circuit.
You still need a driver circuit because the Arduino can't directly supply enough current for a relay coil. You can probably use the 2N2222 for that. Or you can buy a "relay board" which has a relay and river built-in.
You also should be aware than many pieces of electronic equipment these days are double insulated,
meaning that any attempt to connect direct to the circuit might compromize safety - relays are isolated
however (choose a mains rated one), so should retain the double-insulated rating.
For instance its common in equipment with motors to have a floating motor drive circuit powered from
rectified mains directly. Sometimes the whole circuit is at mains potential, but double insulated.
thanks for sharing your knowledge. I understand now why i should use a relay instead of a transistore. Relayboards are not that expensive but need much space. Can you commend some smaller solutions?
An Opto FET is an option in these applications.
H11F1M <200Ω to > 300MΩ
https://www.mouser.ca/datasheet/2/308/H11F3M-D-1810361.pdf
There are small DIP relays too.
