Hey!...I am using ESP32 - S2 DevKitC-1 v1 and i am trying to connect the PN532 to it inorder to do some NFC card detection. but the ESP32 is not connecting with the PN532 over the I2c
Connections:
SDA - GPIO_8
SCL - GPIO_9
VCC - 5v
GND - GND
the code :
#include <Wire.h>
#include <PN532_I2C.h>
#include <PN532.h>
#include <NfcAdapter.h>
PN532_I2C pn532i2c(Wire);
PN532 nfc(pn532i2c);
volatile bool connected = false;
void setup(void) {
Wire.begin(8, 9); // Initialize I2C with SDA on pin 8 and SCL on pin 9
Serial.println("*** Testing Module PN532 NFC RFID ***");
void loop(void) {
boolean success;
// Buffer to store the UID
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };
// UID size (4 or 7 bytes depending on card type)
uint8_t uidLength;
while (!connected) {
connected = connect();
// Wait for an ISO14443A type cards (Mifare, etc.). When one is found
// 'uid' will be populated with the UID, and uidLength will indicate
// if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
// If the card is detected, print the UID
if (success) {
Serial.println("Card Detected");
Serial.print("Size of UID: "); Serial.print(uidLength, DEC);
Serial.println(" bytes");
Serial.print("UID: ");
for (uint8_t i = 0; i < uidLength; i++) {
Serial.print(" 0x"); Serial.print(uid[i], HEX);
Serial.println("");
Serial.println("");
else {
// PN532 probably timed out waiting for a card
// Serial.println("Timed out waiting for a card");
bool connect() {
nfc.begin();
// Connected, show version
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.println("PN53x card not found!");
return false;
//port
Serial.print("Found chip PN5"); Serial.println((versiondata >> 24) & 0xFF, HEX);
Serial.print("Firmware version: "); Serial.print((versiondata >> 16) & 0xFF, DEC);
Serial.print('.'); Serial.println((versiondata >> 8) & 0xFF, DEC);
// Set the max number of retry attempts to read from a card
// This prevents us from waiting forever for a card, which is
// the default behavior of the PN532.
nfc.setPassiveActivationRetries(0xFF);
// configure board to read RFID tags
nfc.SAMConfig();
Serial.println("Waiting for card (ISO14443A Mifare)...");
Serial.println("");
return true;
Output:
ESP-ROM:esp32s2-rc4-20191025
Build:Oct 25 2019
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3ffe6100,len:0x524
load:0x4004c000,len:0xa70
load:0x40050000,len:0x298c
entry 0x4004c18c
PN53x card not found!```
