Hi there
I have taken the example Wifi AWS MQTT project across to the H7 and think I have done everything correctly as I have got a similar project working on the MKR 1500. I am using the ArduinoMqttClient library and getting a -2 error on connect
I looked at this post and still no luck
@Electric_Dragon Did you have to do anything different from the original sample WiFi project to AWS MQTT ?
thanks
@jrobertshawe as far as I remember, I did not do anything different to the example project
Thanks @Electric_Dragon. I will keep trying. I used the ECCX08 tool to create a csr , created a thing on AWS and uploaded the CSR - downloaded the cert and added to my secret. This is the code which is a copy of yours - let me know if you can think of anything I may have missed. I did the same steps with the MKR 1500 , it was awhile ago - with these things a small mistake is all it takes to get a -2
https://create.arduino.cc/projecthub/132016/securely-connecting-an-arduino-mkr-wifi-1010-to-aws-iot-core-a9f365
This example code is in the public domain.
#include <ArduinoBearSSL.h>
#include <ArduinoECCX08.h>
#include <ArduinoMqttClient.h>
#include "WiFi.h"
#include "arduino_secrets.h"
/////// Enter your sensitive data in arduino_secrets.h
const char ssid[] = SECRET_SSID;
const char pass[] = SECRET_PASS;
const char broker[] = SECRET_BROKER;
const char* certificate = SECRET_CERTIFICATE;
WiFiClient wifiClient; // Used for the TCP socket connection
BearSSLClient sslClient(wifiClient); // Used for SSL/TLS connection, integrates with ECC508
MqttClient mqttClient(sslClient);
unsigned long lastMillis = 0;
while (!Serial);
if (!ECCX08.begin()) {
Serial.println("No ECCX08 present!");
while (1);
// Set a callback to get the current time
// used to validate the servers certificate
ArduinoBearSSL.onGetTime(getTime);
// Set the ECCX08 slot to use for the private key
// and the accompanying public certificate for it
sslClient.setEccSlot(0, certificate);
// Optional, set the client id used for MQTT,
// each device that is connected to the broker
// must have a unique client id. The MQTTClient will generate
// a client id for you based on the millis() value if not set
// mqttClient.setId("clientId");
// Set the message callback, this function is
// called when the MQTTClient receives a message
mqttClient.onMessage(onMessageReceived);
if (WiFi.status() != WL_CONNECTED) {
connectWiFi();
if (!mqttClient.connected()) {
// MQTT client is disconnected, connect
connectMQTT();
// poll for new MQTT messages and send keep alives
mqttClient.poll();
// publish a message roughly every 5 seconds.
if (millis() - lastMillis > 5000) {
lastMillis = millis();
publishMessage();
unsigned long getTime() {
// get the current time from the WiFi module
return WiFi.getTime();
void connectWiFi() {
Serial.print("Attempting to connect to SSID: ");
Serial.print(ssid);
Serial.print(" ");
while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
// failed, retry
Serial.print(".");
delay(5000);
Serial.println("You're connected to the network");
void connectMQTT() {
Serial.print("Attempting to MQTT broker: ");
Serial.print(broker);
Serial.println(" ");
// while (!mqttClient.connect(broker, 8443)) {
// // failed, retry
// Serial.print(mqttClient.connectError());
// Serial.print("\t");
// delay(5000);
// Serial.println();
Serial.print("Attempting to connect to the MQTT broker: ");
Serial.println(broker);
if (!mqttClient.connect(broker, 8883)) {
Serial.print("MQTT connection failed! Error code = ");
Serial.println(mqttClient.connectError());
while (1);
Serial.println("You're connected to the MQTT broker");
// subscribe to a topic
mqttClient.subscribe("arduino/incoming");
void publishMessage() {
Serial.println("Publishing message");
// send message, the Print interface can be used to set the message contents
mqttClient.beginMessage("arduino/outgoing");
mqttClient.print("hello ");
mqttClient.print(millis());
mqttClient.endMessage();
void onMessageReceived(int messageSize) {
// we received a message, print out the topic and contents
Serial.print("Received a message with topic '");
Serial.print(mqttClient.messageTopic());
Serial.print("', length ");
Serial.print(messageSize);
Serial.println(" bytes:");
// use the Stream interface to print the contents
while (mqttClient.available()) {
Serial.print((char)mqttClient.read());
