Portenta X8 completely not detected over USB, uuu flashing not possible
Hi everyone,
I am using a Portenta X8 with the Portenta Breakout board, and I think my board might be bricked. I was trying to reflash the image using the uuu flashing tool on Windows, following the official “How to update your Portenta X8” documentation.
This is what I did:
  • Downloaded image-latest.tar.gz from the Arduino download page and extracted it.
  • Extracted mfgtool-files-portenta-x8.tar.gz and lmp-factory-image-portenta-x8.wic.gz so that I have the mfgtool-files-portenta-x8 directory and the .wic file in the same folder.
  • Downloaded uuu.exe and put it into the mfgtool-files-portenta-x8 folder.
  • On the Portenta Breakout, I set both BT_SEL and BOOT DIP switches to ON (flashing mode).
  • Connected the Portenta X8 + Breakout to my PC using a USB‑C to USB‑A data cable.
  • Opened an elevated PowerShell and ran:
.\uuu .\full_image.uuu
  • uuu starts correctly and prints:
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.109-0-g6c3190c
Wait for Known USB Device Appear...
The problem is that nothing else ever happens:
  • When I unplug and re‑plug the USB cable, there is no new log line in uuu.
  • Windows Device Manager shows no new device at all when I plug in the board (no COM port, no unknown device, nothing).
  • I tried multiple data cables and multiple USB ports.
  • I also tested on another PC, and it behaves the same (no USB device appears).
Board LEDs:
  • On the Portenta X8, a red LED and a white LED stay on continuously.
  • On the Ethernet port, the LEDs stay on as well.
So the board clearly has power, but it never shows up as a USB device on any computer, and uuu keeps waiting forever for a USB device.
I also tried removing and reseating the Portenta X8 on the Breakout, double‑checking that BT_SEL and BOOT are both ON, and power‑cycling the board several times. It still does not get detected.
At this point, is there any other recovery method I can try, or does this indicate that the board is permanently bricked and needs to be replaced (RMA)?
Any help or official guidance would be greatly appreciated. Thanks in advance.
Hi @jeayonglee , I don't have the X8, so this is a bit of a shot-in-the-dark, but have you tried double-clicking the reset button to put it in bootloader mode? Works on my GIGA (same MCU) when I have a code issue that locks it up.
first thank you for answer, i tried double clicking but didn't solved the problem. same white and red led still on, not changing.
Found this, maybe it will help Portenta X8 not working after update
I faced the same issue today. But then it worked for me. I had to restructure the files in the folder properly according to the user manual.
Did the Arduino Linux Wizard detect your Portenta X8?
I am facing issues in connecting Portenta X8 with the Linux Wizard. Check my other post on this.
can i get a link? your profile is locked
but my portenta is not detected by linux.
thank you for your response. but my device is not detected on any environment or program. maybe my device became bricked
