Hi Everyone,
I'm trying to control a self-balancing car, but it seems that the MPU6050 get dirty once my motors operate a full velocity.
I'm controlling my motors with the module L298N and with the PWM signal (pin 5, 6, 9 and 10 from the arduino).
I have read about decoupling it, with capacitors, but I don't know exactly how should I do it.
This is my code. It's a little messy (sorry for that, it just I'm still figuring out what is going on) and also an image of my project:
#include <PID_v1.h>
#include <LMotorController.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
#define MIN_ABS_SPEED 20
MPU6050 mpu;
#define DEBUG
//#define OFFSET_1
//#define STOP
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorFloat gravity; // [x, y, z] gravity vector
float euler[3]; // [psi, theta, phi] Euler angle container
//PID
//double originalSetpoint = 175.8;
#ifdef OFFSET_1
double originalSetpoint = 225;
#else
double originalSetpoint = 184;
#endif
double setpoint = originalSetpoint;
double movingAngleOffset = 0.1;
double input, output, output_left, output_right, error;
int moveState=0; //0 = balance; 1 = back; 2 = forth
double Kp = 40;
double Kd = 0.05;
double Ki = 5;
PID pid(&input, &output, &setpoint, Kp, Ki, Kd, DIRECT);
double motorSpeedFactorLeft = 1;
double motorSpeedFactorRight = 1;
double motorSpeedFactorForward = 1;
double motorSpeedFactorBackward = 1;
//MOTOR CONTROLLER
int ENA = 5;
int IN1 = 6;
int IN2 = 7;
int IN3 = 8;
int IN4 = 9;
int ENB = 10;
//LMotorController motorController(ENA, IN1, IN2, ENB, IN3, IN4, motorSpeedFactorLeft, motorSpeedFactorRight);
//timers
long time1Hz = 0;
long time5Hz = 0;
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady()
mpuInterrupt = true;
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
Wire.setClock(400000); // Set the SCL clock speed to 400kHz
//Wire.setClock(200000); // Set the SCL clock speed to 400kHz
//TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
//Fastwire::setup(200, true);
#endif
mpu.initialize();
devStatus = mpu.dmpInitialize();
// supply your own gyro offsets here, scaled for min sensitivity
#ifdef OFFSET_1
mpu.setXGyroOffset(0);
mpu.setYGyroOffset(0);
mpu.setZGyroOffset(0);
mpu.setZAccelOffset(16372);
mpu.setYAccelOffset(5);
mpu.setXAccelOffset(2);
#else
mpu.setXGyroOffset(-52);
mpu.setYGyroOffset(-12);
mpu.setZGyroOffset(53);
mpu.setZAccelOffset(2420);
mpu.setYAccelOffset(2881);
mpu.setXAccelOffset(-784);
#endif
// make sure it worked (returns 0 if so)
if (devStatus == 0)
//mpu.CalibrateAccel(6);
//mpu.CalibrateGyro(6);
// turn on the DMP, now that it's ready
mpu.setDMPEnabled(true);
// enable Arduino interrupt detection
attachInterrupt(0, dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
// set our DMP Ready flag so the main loop() function knows it's okay to use it
dmpReady = true;
// get expected DMP packet size for later comparison
packetSize = mpu.dmpGetFIFOPacketSize();
pid.SetMode(AUTOMATIC);
pid.SetSampleTime(10);
pid.SetOutputLimits(-255, 255);
// ERROR!
// 1 = initial memory load failed
// 2 = DMP configuration updates failed
// (if it's going to break, usually the code will be 1)
Serial.print(F("DMP Initialization failed (code "));
Serial.print(devStatus);
Serial.println(F(")"));
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
#ifdef STOP
return;
#endif
// if programming failed, don't try to do anything
if (!dmpReady) return;
// wait for MPU interrupt or extra packet(s) available
while (!mpuInterrupt && fifoCount < packetSize)
pid.Compute();
output = 255;
output_left = output * motorSpeedFactorLeft;
output_right = output * motorSpeedFactorRight;
if(input > (setpoint))
output_left = output_left*motorSpeedFactorForward ;
output_right = output_right* motorSpeedFactorForward;
Move_Forward();
else if(input < (setpoint))
output_left = output_left*motorSpeedFactorBackward ;
output_right = output_right* motorSpeedFactorBackward;
Move_Backward();
Stop();
// reset interrupt flag and get INT_STATUS byte
// get current FIFO count
fifoCount = mpu.getFIFOCount();
// check for overflow (this should never happen unless our code is too inefficient)
if ((mpuIntStatus & 0x10) || fifoCount == 1024)
// reset so we can continue cleanly
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
// otherwise, check for DMP data ready interrupt (this should happen frequently)
else if (mpuIntStatus & 0x02)
// wait for correct available data length, should be a VERY short wait
while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
// read a packet from FIFO
mpu.getFIFOBytes(fifoBuffer, packetSize);
// track FIFO count here in case there is > 1 packet available
// (this lets us immediately read more without waiting for an interrupt)
fifoCount -= packetSize;
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(euler, &q, &gravity);
input = (euler[1] * 180 / M_PI + 180);
error = input - setpoint;
// Serial.print("\tOutput: ");
// Serial.print(output);
Serial.print("\tError: ");
Serial.println(error);
void Move_Forward() //Code to rotate the wheel forward
//******RIGHT******//
analogWrite(5, -1*output_right);
analogWrite(6, 0);
//******LEFT******//
analogWrite(9, -1*output_left);
analogWrite(10, 0);
digitalWrite(11, HIGH);
digitalWrite(12, LOW);
void Move_Backward() //Code to rotate the wheel forward
analogWrite(5, LOW);
analogWrite(6, 1*output_right);
analogWrite(9, 0);
analogWrite(10, 1*output_left);
digitalWrite(11, LOW);
digitalWrite(12, HIGH);
void Stop() //Code to rotate the wheel forward
analogWrite(11, LOW);
analogWrite(12, LOW);
analogWrite(6, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
