Potentiometer controlling arduino
I have been working on a project where 14 servo motors are connected to a Arduino Uno r3 and potentiometers controll each one but I don't know how to attach the servos to a Arduino while allowing the potentiometers to controll each one can anyone help me or show me a instruction page online with the code attached.
Welcome to the forum
Show your work
Why 14 and not 1? Start small
Read this
To control 14 servos and read 14 potentiometers you will need external hardware. An Uno can only, directly, control 12 servos and has 6 ADC pins.
16 channel servo controller
16 channel Analog multiplexer.
But what's the code for that I don't know how to code that much
I have been working on a project where a line of 14 servo motors are connected to a Arduino Uno r3 and potentiometers controll each one but I don't know how to attach the servos to a Arduino while allowing the potentiometers to controll each one. I was wondering if this can be done on 1 arduino Uno r3 because there are not enough slots on a Arduino Uno r3 and if there is a way it can be done can someone pleas send instructions on how to do it with the code I have already done a project like this befor but it used only 4 servos to make a robot arm for 5hia porjec5 I'm trying to make a line of cups that go up and down using a mechanisim that uses the servos to bring them up and down could someone help me I already posted a question like this but someone told I needed to showy work and why 14 servos not 1 so I explained it here.
I already did a project using 4 servos and it worked so now I'm doing 14 for a different project
Brilliant, so no problem then! The code for 4 that I can’t see works so you should expand that.
