Pots do not control relay times
Beginner´s question ahead...
Hello, I want to control the on/off state of a 4 ch. relay module (velleman) with 4 potentiometers.
I found a code to control the 4 relays at the same time in a non-blocking fashion.
// Which pins are connected to which RELAY
const byte RELAY01 = 2;
const byte RELAY02 = 3;
const byte RELAY03 = 4;
const byte RELAY04 = 5;
// Time periods of blinks in milliseconds.
const unsigned long RELAY01interval = 1000;
const unsigned long RELAY02interval = 1000;
const unsigned long RELAY03interval = 1000;
const unsigned long RELAY04interval = 1000;
// Variable holding the timer value so far. One for each "Timer"
unsigned long RELAY01timer;
unsigned long RELAY02timer;
unsigned long RELAY03timer;
unsigned long RELAY04timer;
void setup ()
  pinMode (RELAY01, OUTPUT);
  pinMode (RELAY02, OUTPUT);
  pinMode (RELAY03, OUTPUT);
  pinMode (RELAY04, OUTPUT);
  RELAY01timer = millis ();
  RELAY02timer = millis ();
  RELAY03timer = millis ();
  RELAY04timer = millis ();
  }  // end of setup
void toggleRELAY01 ()
   if (digitalRead (RELAY01) == LOW)
      digitalWrite (RELAY01, HIGH);
      digitalWrite (RELAY01, LOW);
  // remember when we toggled it
  }  // end of toggleRELAY01
  void toggleRELAY02 ()
   if (digitalRead (RELAY02) == LOW)
      digitalWrite (RELAY02, HIGH);
      digitalWrite (RELAY02, LOW);
  }  // end of toggleRELAY02
    void toggleRELAY03 ()
   if (digitalRead (RELAY03) == LOW)
      digitalWrite (RELAY03, HIGH);
      digitalWrite (RELAY03, LOW);
  }  // end of toggleRELAY03
      void toggleRELAY04 ()
   if (digitalRead (RELAY04) == LOW)
      digitalWrite (RELAY04, HIGH);
      digitalWrite (RELAY04, LOW);
  }  // end of toggleRELAY04
void loop ()
  // Handling the blink of one relay. The other Relays are controlled the same way. Repeat for more Relays
  if ( (millis () - RELAY01timer) >= RELAY01interval)
     toggleRELAY01 ();
  if ( (millis () - RELAY02timer) >= RELAY02interval)
    toggleRELAY02 ();
  if ( (millis () - RELAY03timer) >= RELAY03interval)
     toggleRELAY03 ();
  if ( (millis () - RELAY04timer) >= RELAY04interval)
     toggleRELAY04 ();
/* Other code that needs to execute goes here.
   It will be called many thousand times per second because the above code
   does not wait for the LED blink interval to finish. */
}  // end of loop
Now, instead of a set value of time period in blinking relays, I want to read that from analog input from 4 potentiometers. There is where I got stucked, I tried with analogread with no luck...maybe is very simple but I can´t find the way..
here is the code I have been using:
const unsigned long RELAY01interval = analogRead(A0);
const unsigned long RELAY02interval = analogRead(A1);
const unsigned long RELAY03interval = analogRead(A2);
const unsigned long RELAY04interval = analogRead(A3);
void setup ()
  }  // end of setup
void loop ()
     toggleRELAY01 ();
    toggleRELAY02 ();
     toggleRELAY03 ();
     toggleRELAY04 ();
}  // end of loop```
What potentiometer(s) are you using and how have you connected them up to your Arduino?
Do you want to vary the times while the code is running, or read once after a reset/power up?
If the latter, move your 4 analog reads into setup (but leave the variable declarations before setup, minus the "CONST" declaration).
If you want to vary the pots during running, the reads will have to go into loop().
Secondly, you'll have to scale each analog read to give a suitable time period; as it is, you'll get a value between 0 and 1023, presuming you're using an Uno or Nano, but you probably want to change that to a number between, say, 500, and 2500.
You only read the value of the inputs once when declaring the interval variables and to make things worse they are declared as const which means that they cannot be changed later even if you wanted to
Is that what you want to do, bearing in mind that the maximum value read will be 1023 on most Arduinos. Which Arduino are you using ?
look this over
const byte PinLed [] = { LED_BUILTIN };     // just one
const int  Nled = sizeof(PinLed);
const byte PinPot = A0;
unsigned long msecPeriod;
unsigned long msecLst;
void
loop ()
    unsigned long msec = millis ();
    msecPeriod = 10 * analogRead (PinPot);
    if (msec - msecLst >= msecPeriod)  {
        msecLst = msec;
        for (int n = 0; n < Nled; n++)
            digitalWrite (PinLed [n], ! digitalRead (PinLed [n]));
void
setup  ()
    Serial.begin (9600);
        pinMode (PinLed [n], OUTPUT);
My goal is to run the code and have the relay times interacting with the potentiometer dial in real time. I would be changing the values repeatedly moving the knob...
so obviously const is not the way to go
I have 100K and 20K which one do you recommend?
I am connecting left to 5v, right to Ground and center to Digital input pin in arduino
I would like to vary the times while the code is running
Arduino UNO, as mention above i want to "vary the times while the code is running"
so obviously CONST is not the way to go I see
Nor is only reading the pot values once in the sketch. They need to be read in loop() or in a function called from it. Depending on how responsive you need the reaction to changing values to be you could either read them each time through loop() or at fixed intervals. You should also consider only updating the timing values if the pot position has changed significantly
What range of relay timing values are you hoping to use ?
great, thanks, but how can I include that in my code?
I was hoping something like 300 to 3000 milliseconds
The posting #23 has the complete code
This code divides all lines that are nescessary to make it work into sub-units
where each sub-unit has that lines of code that build the senseful sub-unit.
with this structure void loop() looks like this
void loop (){
  readPotentiometers();
  checkRelayTimers_and_toggle();
}  // end of loop
This gives you the overview. More in the next postings...
before presenting more of the code.
You have 4 very very similar things:
  • 4 IO-pins
  • 4 timers
  • 4 potentiometers
  • 4 intervalls
If things are so similar there is a programming-technique called arrays
Your original code defines 4 IO-pins this way
  RELAY01interval = map(analogRead(A0), 0, 1024, 300, 3000)  // map to 300 milliseconds to 3000 milliseconds
sounds like you don't really understand it.
you can add additional relay pin to PinRelay [] without needing to add any additional code
you can also create an array or analog pins and arrays for msecPeriod and msecLast so that each relay is controlled by a separate analog pin.
why don't you study the code some more and give it a try
This can be replaced by an array with 4 elements
this looks like this
const byte relayPin[4] = {2, 3, 4, 5};
// relayPin[0] contains value 2
// relayPin[1] contains value 3
// relayPin[2] contains value 4
// relayPin[3] contains value 5
inside the brackets "[" "]" there is an index-number counting from 0 to 3
The major logic problem is that the OP's code did not read the pots in real time, not the consts.
They are global constants in the code. You could move them down into the loop() and they would be local constants within the loop and be re-initialized to new and different values as the code runs, and destroyed at the end of loop().
void setup ()
  }  // end of setup
void loop ()
     toggleRELAY01 ();
    toggleRELAY02 ();
     toggleRELAY03 ();
     toggleRELAY04 ();
}  // end of loop
Within loop() the 'const' might be confusing and unnececessary, but the code will work.
This principle can be repeated for:
  • the Potentiometer-Pins
  • the intervals
  • the timers
// replaced with an array
const byte potPin[4] = {A0,A1,A2,A3};
// replaced by an array
unsigned long RELAYinterval[4];
unsigned long RelayTimer[4];
// RelayTimer[0] contains value for timer 1
// RelayTimer[1] contains value for timer 2
// RelayTimer[2] contains value for timer 3
// RelayTimer[3] contains value for timer 4
