If I have a LED string of some 30 leds which draws more current than one pin of a ProMini is rated for, but less than the current that the ProMini can supply across multiple pins, what would the result of connecting multiple output pins as per the attached sketch? And yes, I do know that the leds are the wrong way round! Please flip them in your mind!!
All the pins would have to be switched simultaneously of course.
In theory you can do this. But why? You can easily split the LEDs between the pins (i.e. 6 LEDs per pin). It will be safer (no risk of burned pins in case of a bug) and gives you more options - later you may decide to turn on only one group of the LEDs. OTOH I see no advantage of connecting the pins together as shown - unless you need to drive some ready made module that cannot be modified.
Of course using a simple MOSFET (or BJT if you prefer THT components) seems much simpler.
I don't yet have the module, and have no information yet as to its construction (its being supplied to me by a third party). I'm just throwing ideas up in the air at the moment. I'm hoping that the led string can be split.
The problem is that they may not be at the same potential. You would need to use direct port control to switch all pins simultaneously, and even with that there is no guarantee that the outputs will switch within fractions of a nanosecond of each other. Using digitalWrite will definitely destroy the outputs.
