Greetings!
I have the attached project for a small homemade greenhouse automation.
(lease ignore the 4xAA power supplies in the project, I coudlnt find a 12v power supply in Fritzing diagram software...)
I'll be using at least 3 pieces of 12v devices. I have some options for a power supply I can't figure out if its harmful to use a single power supply for multiple devices connected to a 4x12v relay board or not....
Devices:
1- 12v car kettle for heating. I couldnt find specs but im guessing should draw around 4amps
2- A peltier rig for cooling. 12v around 4amps
3- RS360SH water pump. 12v - 4.5 amps
4- A small 12v humidifier
One option is to buy three 12v - 5A power supplies and hook them up as in the diagram....
The other is to buy one 12v - 29A 600W ( FX600-W1V12) power supply and use that with with a 4 x 12v relay board...
Which one would you go with for this project?
