but the power usage from the arduino mini does not goes below the 3,3 Ma
Has anybody a hint for me
or is it not possible with this board to go below the 3,3 ma
on the site where I found this sample was a bare bone used for this experiment
but as far as I Know are there on the mini except for the power led not that much power consumers
If you look at the article you cite, it explains that the reason you cannot reduce the power usage further is that the Mini or Pro Mini has an on-board regulator with a quiescent current draw of a certain number of milliamps. And a "power" LED.
If you want to go lower, you need to assemble your own board in some way - as the article explains - and do without a regulator - generally by using a 4.5V battery.
This morning I looked in the schematic drawing of the Ardino mini board
and found out that the power led has a supply voltage of 5 v and a resistor of 1K ohm in serie
so maximum current could be 5 Ma
I checked that by doing a current measurement parallel over the power led
and measured 4,8 ma
I also measured the voltage drop over the led in normal use and that is 1,8 v
so I can make the following calculation ( correct me if I'm wrong )
the voltage over the resistor = 5v supply voltage minus 1,8 voltage drop over the led = 3,2 v
so the current used by the power led = 3,2v / 1k ohm = 3,2 ma
is this conclusion correct ????
if so I will have to remove the led to reduce the current usage or buy a other board
like a pro mini which has a resistor from 10k Ohm before the power led
That sounds right. Of course anything that generates light is going to consume quite a bit of current. As my article explains, if you must have a power LED, just pulse it for 5 milliseconds or so (per second or two) to reduce the average consumption.
I Think that my thoughts are confirmed by the previous replies
and I think I have to remove the power led witch can not unfortunately disabled by a jumper or so
Thanks everybody for your help it was very useful for me
On the Pro Mini people often cut a PCB track as shown here:
There might be an equivalent on your board. Have a look at the schematic.
