Hi all,
There's been a lot of talk on powering arduino's.
But I would like to explain my specific case and my proposed solution and see if anyone has some wise words, agree or disagree with my solution.
My case:
12 Arduino Pro Mini's 5V spread over a 120 meters, every 10 meter, there will be an Arduino.
Arduino's will run simple sketch with:
- A small PIR sensor, monitoring constantly
- a MAX488CPA+ for full duplex rs485 sending a few bytes (on masters request) every 100ms through FTP5e cabling (arduino's <-> master is 125 to 250meters apart)
2 Arduino's will also have a Weather sensor shield and Weather Meters (Sparkfun).
Computer (master in rs485 chain) is at least 125 meters away from the first Arduino, running MAX/MSP and a whole lot more, but that's not important for now.
The installation will need to run approx 8hrs during daytime, for 12 days.
My solution and thoughts:
Powerconsumption will be quite low
MAX288 specs at 0.12mA
PIR (mini) specs at 0.40mA
Ardiuno aprox. 1mA? (can't actually find any thing on that)
We will leave the 2 Weather stations out of the equation for now.
So my idea is to power each arduino from a USB Power Bank (2200mA?) and take those powerbanks inside during the night to recharge, if needed.
I would rather stay away from using 220v at the location of each arduino.
I can potentially supply 220v AC power from a location 125 meters away from the first arduino (where the computer is, which is a 250meters away from last arduino)
It is all part of a metal structure, outdoors, in potentially foul weather and people will walk through it. (it's an interactive art installation)
I still need to develop/search for an enclosure for each arduino with PIR and a possible powerbank.
Will largely depend on power solution / size.
Does anybody have any thoughts on my proposed solution of using a powerbank that can be taken out from the 'water-tight' enclosure to re-charge at night? What would be my approx. power needed for at least 8hours. Will a 2200mA powerbank keep me running for quite a while?
I though about solar panels too, but since this is a temporary (12days) installation and costs are also to be considered, I don't think that is a sensible/affordable way to go...
Maybe someone has some ideas/comments on the above described installation...or is just interested in more info or anything. I will try and publish a full build story and share experiences when it is all done.
I thought I could at least share my ideas with the community and see if someone has any comments.
Regards,
JD
