I am building a hexapod with 6 leg, each leg consist of 3 servos, there are total of 18 servos. The servo motor I using is MG90S.
According to online specification:
Operating Voltage : 4.8V to 6V (Typically 5V)
Current (typical during movement) : 120-250mA
Current (stall) : 700mA (measured)
Which mean 18 servos required current is approximately (0.25A * 18) = 4.5A , voltage max is 5V. If one or more servos in your hexapod are unable to turn (stalled or blocked), the current will be redistributed to the other servos. This can lead to damaging the servos.
Currently I have a SY8205 (synchronous step- down DC-DC converter) in hand, can this help to better managing the power?
Is there a better way to manage the power? Can advise ?
The usual advice is that the power supply should be able to provide at least 1 Ampere per moving SG90 servo. If too little, you will have a twitching mass of servos, which can be pretty funny.
Not true. Servos, and other components, draw current from the power supply.
Currently the servo's Vcc and gnd are connected in common using breadboard. I used DC power supply to power them. Our testing currently only 12 servo able to move. Can't move when try to power 18 servo. I am using Arduino UNO.
Seriously underpowered. Although exact conditions vary, as do the servo specs, it's wise to budget between 0.75 and 1.0 Ampere per servo; you've got an indication with that 700 mA spec(what they're really saying is, of the last N tested, either the average, or the max, was 700 mA; exactly which, well... it's China, right?). When a servo starts from rest, it draws that current until movement is established (the motor has a stalled rotor until movement happens). If you carefully tune your code to not start more than one at once, offsetting by 50 ms or more, you can get away with less, UNTIL the moment when something binds and several servos are stalled simultaneously.
Less might, maybe, work in most circumstances, but you can bet that the first time you 'show it off' to someone, Murphy will come calling.
In addition, using your breadboard as a power distribution center for the current needed for 18 servos is a non-starter. Breadboard contacts shouldn't be subjected to any more than 100 mA, if you want to use the breadboard indefinitely. Use a power distribution board, a set of wire nuts, or lever-nuts to fan out your power supply current.
