Powering a stepper motor 5V 28BYJ-48
I wanted to power the Arduino and 1 stepper motor using batteries without the USB cable supply.
I use 28BYJ-48 5V stepper motor with ULN2003 driver and 9V battery as supply but not enough . Can I use 2pcs 18650 3.7 battery just like this setup but I use Arduino Uno and I will use 18650 battery
A pair of 18650s in series (7.4 volts) and buck converter down to 6V (remember, the ULN is going to drop about 1.2 ~ 1.5V) and power the UNO from 7.4V through the barrel plug or VIN pin. Do not connect 6 volts to the UNO.
A 9volt smoke alarm battery can't provide the current for a motor.
Four AA batteries would be ok though, for a while.
I would use one 18650 first, and see if torque/speed fits your requirement.
Leo..
Thank you
So I would put a buck converter before connecting it to the ULN driver ?
Yes, motor is 5V, 9 would burn it out. 9V battery -> buck -> ULN -> motor.
Yes that is perfect. No boost or buck needed
Well if you use 2 batteries you will have 7.4V.
The ULN driver will drop that to about 6.4V. So you will be applying 6.4V to the motor.
If you use a 5V buck, the ULN will still drop drop the voltage by about 1V. So you will be applying 4V to the motor.
The optimal solution would be to use a 6V buck, then 5V would go to the motor
If you use 6.4V the motor may wear out a little faster.
If you use 4V, it may not work.
6V is just right.
I leave the choice to you
Or you could do this:
The 1N4002 diode will drop the battery voltage about 1V, so the voltage going to the motor wiil be about 5.4V
It'a stepper motor, so it moves in small steps and won't be real smooth.
The RPM will depend on how fast your code runs but I don't think the motor will move any faster than 20RPM when it's powering a little car
About 12 to 15 RPM is all you're going to get without missing steps and stalling, unless you use a library that can provide acceleration / deceleration like AccelStepper or MobaTools.
Drop back to 12 RPM and see if it stops skipping.
