Powerscript program not seeing Arduino Nano Every serial signal until Arduino IDE serial monitor is opened
I have an Arduino Nano Every and am using it to send a serial signal to my computer over COM5 when an external event happens that gives the Arduino's D2 pin an ON signal. The Arduino sees this signal on pin D2 and sends the serial signal to the computer. I want to be able to use this setup so that I can unplug and replug my Arduino from my computer using a USB cord, and then have the external event happen and the Arduino send the signal to my computer. I am using a PowerScript program to look on COM5 for the serial signal and close when it is seen. However, the problem is that I have to open and close the Serial monitor on the Arduino IDE before I can start the Powerscript program and have it work properly. If I don't, then the Powerscript program runs, but never sees the Arduino signal and never closes. What is the problem here? And how could I fix this so that I can simply plug in the Arduino to my computer, run the PowerScript program and get my serial signal when the Arduino external event happens.
Here is my Powerscrip program:
$portName = "COM5"  # Modify to your actual port name
$baudRate = 9600
function Open-Port {
    param (
        [string]$portName,
        [int]$baudRate
    $port = new-Object System.IO.Ports.SerialPort $portName, $baudRate, None, 8, one
    try {
        $port.Open()
        Write-Host "Port opened successfully."
    } catch {
        Write-Host "Error: $_.Exception.Message"
        return $null
    return $port
$port = Open-Port -portName $portName -baudRate $baudRate
if ($port -eq $null) {
    Write-Host "Failed to open port. Exiting..."
    exit 1
Write-Host "Listening on $portName. Press Ctrl+C to exit manually."
try {
    while ($true) {
        if ($port.BytesToRead -gt 0) {
            $input = $port.ReadLine()
            Write-Host "Received: $input"
            if ($input -match "fire") {  # Modify to the signal you expect
                Write-Host "Trigger signal received. Exiting..."
                break
#        Start-Sleep -Milliseconds 100  # Delay to reduce CPU usage
finally {
    if ($port -and $port.IsOpen) {
        $port.Close()
        Write-Host "Port closed."
exit 0
Here is my Arduino program that I have uploaded to the Arduino prior to everything happening:
const int ttlPin = 2; // Define the digital input pin connected to the DDG
  pinMode(ttlPin, INPUT); // Set as a normal input mode
  Serial.begin(9600); // Initialize serial communication
  // Serial.begin(115200); // Initialize serial communication
  int ttlValue = digitalRead(ttlPin);
  // High level detected
  if (ttlValue == HIGH) {
    Serial.println("fire");
    delay(100); // Delay for 1000 milliseconds
Comment out the Serial statements and see if that works.
Do you mean the Serial.begin and Serial.println in the Arduino code?
Yes, your problem description very clearly indicates something is waiting on the Serial device. In order to prove/disprove that, just comment out those lines.
If I did that, then my Arduino wouldn't be able to send a serial signal to my laptop.
I fixed the problem by initially opening the port to reset the Arduino using PuTTY and then closing it. The next line in the command prompt runs the PowerScript code that opens the port and waits for the signal. This works! Although it does seem overly complicated for what I needed to do and there still may be a more elegant solution. But hey, now I can just hit one button and the computer can wait for the signal!
What I suggested wasn't the fix, it was simply to prove what was causing the hang. If you are happy with what you have then ignore this. Have you tried Software Serial?
