Practical Essentials
Things that helped me a lot.
Clips : seriously stability, is probably the most important thing. So clip your wire.
1A fuse from relay COM clipped
On a plastic box
Professional ? Nops..
Gave me the stability i need to achieve something safely ? Yes…
I will get to the smd, perf board version after testing and learning… i hope and yes…
Stability is key
This the usb wire for an uno, clip it…
It will hold the board in place….
Where to clip it ?
Get trays ! Seperate components, relay far away. Random 5V wire you forgot hanging from uno ? Gnd wire you connected to a sensor then forgot on the table ? Now adc shifts 0.2 V out of no where and your hall sensor and voltage divider is showing a completely wrong voltage..
Well at least the wire is in a tray, separate from your mosfet.
After testing picture
Nothing is clean, very “unprofessional” wires all over the place. BUT safe… and when i rested cleaned up
So trays….
The smaller the better
Thats a ph meter with an oled
Hopefully soon this will become a compact board. But for now until i figure out all the ins and out. It works !
BC337 transistor….
Insulate your dip fuses if you can…
Make things usable, and use them.
The images are dark and unclear, sorry
Welcome
Interesting but I cannot follow it. Even if the pictures were clear it is to complicated to build from pictures. An annotated schematic along with links to technical information on the components would be a big help.
Not sure what you want to accomplish. Is there a problem?
I use the plastic ones that come in different colors rather than the wood ones. In case others don't know, they are clothes pins
:+1:
I think I understand where you are going with this...You are just showing how you keep your projects as tidy as you can?
  • The clothes pins are a good idea.
  • I also label my resistors if it isn't for an led or something I use a lot.
  • I like the tray idea to.
I built a button and switch board with headers for everything, plus extra Vin and GND headers. It has 20 buttons, 12 dip switches, 3 potentiometers, and two XY joysticks with built in buttons. It is handy. I should have added multiple LEDs of various colors to it.
I need to get longer jumpers. Mine are always to short!
Agree with the of importance of 'stability'. As well as 'clips' (including occasional small pieces of BluTack or similar), I find breadboards a major culprit. Especially the very small ones which slide so easily. And the familiar DuPont connectors.
I might test out small parts of a project on a prototype ( eg using chip I’ve not used before ), but quickly go to a PCB - they are so cheap, esp if you are working on more than one design at a time .
I find if you use a prototype board screw it to a piece of wood with the terminations display etc to give it stability .
and you can make yourself PCB with various bits a pieces to help you prototype :
leds, pots , switches , different voltages , voltmeter , usb break out , holder for uno , 5v to 3v3 dividers , wagos to the outside world , 0v bus , etc etc
