Pressure Sensor Trouble
I have been trying to use a pressure sensor to sense air pressure in PSI.
Im using an Arduino Uno.
Im using this one.
I is 5V and it is supposed to sense 0-100PSI
It has 3 wires.
Black is -
Red is +5
Green is Sensor output. I have this one hooked up to Analog 0 on the Arduino Uno i'm using.
Anyway, i get the same reading from the Green sense wire no matter what pressure it sees.
It is always 4.95V.
I have tried it a 40 PSI, 30 PSI, 25 PSI and also disconnected from the pressure tank.
The sensor has the following documentation:
Output: 0.5V~4.5V linear voltage output. 0 psi outputs 0.5V, 15psi outputs 2.5V, 30 psi outputs 4.5V.
So first of all 4.95 is more than the 4.5 that they mention.
This makes me wonder if I have it hooked up wrong?
I have the red +5 going to the +5 pin on the uno, the black - hooked up to the gnd on the Uno, and the green output on the Analog 0 pin on the uno.
This is the code im using:
const int analogPin = A0;
float inputP1;
float voltageP1;
float psiP1;
 Serial.begin(9600); // open the serial port at 9600 bps:
 inputP1 = analogRead(A0);
 voltageP1 = ((float)inputP1* (5 / 1023.0));
 psiP1 = ((float)inputP1/1023*100);
Serial.print("VOLTAGE = ");
Serial.print(voltageP1);
Serial.print("PSI = ");
Serial.print(psiP1);
 delay (500);
Also I have confirmed the reading by using a volt meter to read the green output wire rather than that Uno.
I get the same results.
Please edit your post to add code tags.
That is the symptom of a faulty ground connection. Are you sure that you have made a good ground connection?
Recheck all connections, and use your multimeter to verify connection continuity, as well as proper sensor function.
You can try the code below. You may have to adjust the mapping numbers (0-100), But this may help you get closer to what you are looking for...
Let me know if this helps...
int PS = A0; // Pressure Sensor
int PSR = 0; // Pressure Sensor Reading
  pinMode(PS, INPUT);
  PSR = analogRead(PS);
  delay(250);
  PSR = map(PSR, 0, 1023, 0, 100); //Changes voltage into PSI.. Analog--->Digital
  Serial.print("Pressure: ");
  Serial.println(PSR);
  Serial.println("   ");
  delay(250);
Read the reviews. Seems like about a 50/50 failure rate. I have read on a lot of automotive sights that these cheap Chinese sensors are a gamble.
Also the specifications are wrong. At 0 psi it should read .5V and at 100 psi 4.5V.
detown:
Actually 10% of VCC @ 0 psi and 90% of VCC @ 100 psi.
Sensors like this are ratiometric, and 5volt is never 5.000volt.
Therefore better to code in A/D values, not in 'volts' (you're not making a voltmeter).
Test sketch attached.
Leo..
const byte pressurePin = A0;
float sensorType = 100.0;
const int offset = 102; // zero pressure adjust
const int fullScale = 922; // max pressure adjust
float pressure; // final pressure
  pressure = (analogRead(pressurePin) - offset) * sensorType / (fullScale - offset);
  Serial.print(pressure, 1); // one decimal place is all you're getting with a 10-bit A/D
  Serial.println(" psi");
Thanks for the explanation.
Karma added.
