Problem choosing the right solar panel - Arduino micro weather station
I need help choosing the proper solar panel for our on-field weather station, based on Genuino
micro, with a mean energy consumption of 26.28 mA (26 in sleep and 47 reading every 10
minutes for 8s).
The power supply consists on 4 Ni-MH AAs in series, with a capacity of 2400 mAh.
The aim of our project is to guarantee to the weather station a complete energetic autonomy for
several months.
Which solar panel specifications do we need to make it happen? is there a simple method to
hook up the solar panel to arduino and to the batteries?
Thanks!
PietroIbba:
a mean energy consumption of 37 mA (26 in sleep and 47 reading).
I doubt that your arduino is aquiring data 50% of the time.
You can reduce the consumption of the arduino into the 10s of µA when sleeping, so it shouldn't be a problem to achieve an average consumption of less than 1mA.
In that case, your station could be powered solely from your batteries for months, without any solar panel.
lg, couka
couka:
Thank for pointing that out, i have corrected the previous post.
couka:
We already reduced the energy consumption to a minimal value for our configuration, so right now we are focusing on adding a solar panel suitable for our purpose with the consumption values mentioned above.
Thank you,
Pietro
PietroIbba:
Out of curiosity, what's drawing so much current then? 26mA is quite a lot for doing nothing :slight_smile: Status LEDs maybe?
To be on the safe side, I calculated with 50mA average draw, which results in a consumption of ~2,2kWh/year. As a rule of thumb, that means you need a solar panel with 2,2W peak power, depending on where you live.
That's under optimal conditions concerning placement of the panel and at least average weather.
lg, couka
couka:
Definitely status LEDs :D, and maybe the SD card that is not going in sleep mode.
couka:
Do we have to consider also the consumption resulting from the recharge of the batteries? or it is included in your calculation?
Pietro
Firstly you need to figure out the average cloudless solar radiation you'll get at midwinter, then derate that by
a factor of 20 or so to allow for fully overcast days. Your system uses 26mA on average, I'd expect you
need a panel capable of 2 to 4A or more to do this reliably at a guess, depending on lattitude. The worst
case is very very much worse than the best case.
You didn't say if the "several months" included winter though.
Your 2.4Ah battery will need derating as those capacity figures only hold for a brand new battery
fully charged at a particular temperature and discharge rate. However its good for several days anyway,
it only has to be good for 24 hours to work.
You should consider using a board designed for micro-power operation, since you can get the consumption
down to a few microamps if you do things right - the Uno has a USB-serial chip on it that doesn't have
a sleep mode, so its not designed for battery operation.
MarkT:
Your system uses 26mA on average, I'd expect you need a panel capable of 2 to 4A or more to do this reliably at a guess, depending on lattitude.
Could you explain in other words why i need a solar panel capable of 2 to 4A, i thought that a smaller one would have been enough (300 - 400 mA)
MarkT:
No winter is not included, the period would be at least of 7/8 months, from late April to the end of October.
You should be able to reduce the average power consumption to the point that 3 AA batteries would power the system for months. No solar panel needed.
Read carefully and embrace this tutorial on power savings.
Really need a bit more info about the weather station , ie what sort of sensors does it have?
Do any of the sensors draw current all the time ?
Let's assume you have solar power for 6 good hours during a day. So your batteries only need to power the Arduino for the rest 18 hours.
So 18h x 0.03A x 4.8V = 2.6Wh . Battery need to charge for the lost 2.6Wh in 6 hours time.
You will need a solar panel of 6V and atleast 100mA or more(without taking winter into consideration).
Anyways your project has a problem. Long term charging of NiMH cells without any controller board will damage those cells.
If you can switch to a Li-ion ICR cell then that problem can be easily solved.
PietroIbba:
Remove them then. Reducing the current consumption is a lot easier than using PV and it's cheaper, more reliable and more elegant as well.
lg, couka
mauried:
The equipped sensors are:
  • DHT22
  • BMP180
  • DS18B20
  • Thermistore 10k
  • Soil moisture sensor
  • Photoresistor LDR 20-50k
Every sensor is turned ON only when it needs to read.
couka:
We will certainly remove the LEDs, but i think that other than that we will only focus on a solar power supply for the existing wheater station and its current energy consumption.
