Hi All,
I can't get communication going with a Sensirion sps30 (particle sensor) I bought, on my Arduino Mega.
My Sketch is below (thanks to another who got this Sensor working).
I cannot get anything other than "Troubles" as the feedback, suggesting the sensor is not communicating. In Serial Monitoring, its just says "Troubles".
Under Sketch > Include Library > Contributed Libraries its shows Sensirion SP library and DHTLib ; So I assume the needed library files are OK and in there ?
I have set the Baud to 115,200
I have put 5v DC into sensor Pin 1 and Pin 5 is Ground
Pin 4 is Ground so triggering I2C is selected
Pin 2 (SDA) plugged into pin 27
Pin 3 (SCL) plugged into Pin 28
By the way I have not seen anywhere that says where to plug in SDA and SCL into the Arduino, I presume it scans for connection and you can put it into any Digital Pins ?
I have tested and 5v is measured across pin 1 and Pin 5
Thanks if anyone knows how to solve.
Great
SKETCH :
uint8_t buf_start[8]={0x7e, 0x00, 0x00, 0x02, 0x01, 0x03, 0xf9, 0x7e};
uint8_t buf_stop[6]={0x7e, 0x00, 0x01, 0x00, 0xfe, 0x7e};
uint8_t buf_read[6]={0x7e, 0x00, 0x03, 0x00, 0xfc, 0x7e};
uint8_t buf_rst[6]={0x7e, 0x00, 0xD3, 0x00, 0x2c, 0x7e};
uint8_t buf_PN[7]={0x7e, 0x00, 0xD0, 0x01, 0x01, 0x2D, 0x7e};
uint8_t buf_AC[7]={0x7e, 0x00, 0xD0, 0x01, 0x02, 0x2C, 0x7e};
uint8_t buf_SN[7]={0x7e, 0x00, 0xD0, 0x01, 0x03, 0x2B, 0x7e};
Serial.begin(115200,SERIAL_8N1);
delay(100);
//reset sensor
Serial.write(buf_rst,6);
readme();
delay(5000);
int len=0;
uint8_t buff[60];
/* Serial.write(buf_PN,7);
readme();
Serial.write(buf_AC,7);
readme();
Serial.write(buf_SN,7);
readme();
delay(1000);*/
Serial.write(buf_start,8);
readme();
delay(10000);
while(1)
delay(2000);
Serial.write(buf_read,6);
readme();}
Serial.write(buf_stop,6);
readme();
void errorCode(uint8_t state){
switch (state)
case 0:
Serial.println("No error");
case 1:
Serial.println("Wrong data length for this command (too much or little data)");
case 2:
Serial.println("Unknown command");
case 3:
Serial.println("No access right for command");
case 4:
Serial.println("Illegal command parameter or parameter out of allowed range");
case 40:
Serial.println("Internal function argument out of range");
case 67:
Serial.println("Command not allowed in current state");
default:
Serial.println("Unknown error code");
void CMD(uint8_t state){
switch (state)
case 0:
Serial.println("Start measurements");
case 1:
Serial.println("Stop measurements");
case 3:
Serial.println("Read measured value");
case 0x80:
Serial.println("Read/Write Auto Cleaning Interval");
case 0x56:
Serial.println("Start Fan Cleaning");
case 0xD0:
Serial.println("Device Information");
case 0xd3:
Serial.println("Reset");
default:
float decimal = 0.0f;
int integer;
void readme(){
if (Serial.read()==0x7e)//Start with 0x7e
{ if (Serial.read()==0)//Address is always 0
{CMD(Serial.read());//Command
errorCode(Serial.read());//State
len=Serial.read();//Read data length
int j=0;
do{buff[j]=Serial.read();
j++;
}while(buff[j-1]!=0x7e); //read data+checksum to the 0x7e
if (len>0){//for read procedure
for(int i=0; i<(j-2);i++){//replace special values and
if (buff*==0x7d){*
_ if (buff[i+1]=0x5E){buff*=0x7E;};_
_ if (buff[i+1]=0x5D){buff=0x7D;};
if (buff[i+1]=0x31){buff=0x11;};
if (buff[i+1]=0x33){buff=0x13;};*_
* for (int c = i + 1; c < (j-3); c++){buff*
c*_</em></em></em> <em><em><em><em>* = buff[c+1];} } } //to float convertion for(int i=0;i<10;i++){ integer=((buff[4*i]<<24)|(buff[4*i+1]<<16)|(buff[4*i+2]<<8)|buff[4*i+3]); memcpy(&decimal, &integer, sizeof(integer)); Serial.print(decimal); Serial.print(" "); }//show data } Serial.println(); }}//no troubles else { Serial.println("Troubles");//is troubles } }*</em></em></em></em> <em><em><em>_*
